Thread: 2.0 Tfsi re-map
  1. 2.0 Tfsi re-map
    Dec 2007
    Ellon, Aberdeenshire
    After trading in my S4 for a 2.0 Tfsi (200hp) I'm finding the difference in power a bit dissapointing (unsurprising really)
    Would a re-map make a noticable difference? I find in my new car that a lot of power comes in really early but then fades away towards the top of the rev range.
    I know that I'll never be able to replicate the torque curve of the V8 but I need to do something or my days with this car could be numbered.
    2000 A4 2.5 TDi Quattro Avant (gone) 2004 S4 Avant (gone) 2006 A4 2.0T Fsi Quattro Avant
  2. Re: 2.0 Tfsi re-map
    Mansfield, UK
    The short answer is yes. I can't turn your 2.0T into an S4 but I can try to bridge the gap for you! I have a 2.0T myself and so know the engine fairly well
    First things first - get your diverter valve checked. They turn out to be split more often than not which means they leak boost.
  3. Re: 2.0 Tfsi re-map
    Dec 2007
    Is checking the diverter valve something that I can do, or is it a specialist job?
  4. Re: 2.0 Tfsi re-map
    Mansfield, UK
    It's probably best to go to a specialist, and to be honest it'll be the same labour to check as to fit a new one. They are approximately £40 so depending on the labour it might be worth just fitting a new one in any case.
  5. Re: 2.0 Tfsi re-map
    Sep 2009
    United Kingdom
    Can you post up the results if you fit a new one, I too am after a little bit more from my 2.0 TFSI as I thinks its a little flat on pull away...
  6. Re: 2.0 Tfsi re-map
    Mansfield, UK
    I'll take a picture of a split one I have in the garage tomorrow.. it's really worth the few £ to get it changed. Thankfully there is an OE piston type available now as a replacement.
  1. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  2. Newbie ere. cant decide between 1.8 TFSI or 2.0 TFSI
    By jinky in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-08-2009, 11:36 AM
  3. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  4. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  5. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
