Thread: aftermarket stereo help needed asap
  1. aftermarket stereo help needed asap
    Sep 2009
    lanark, scotland
    bought a jvc stereo and tried installing it into my audi a4 1996. i have put a new fuse in the car and stereo, new harness and still there seems to be no power to the cd player, it is i bose system but this means nothing to me please help me
  2. Re: aftermarket stereo help needed asap
    Apr 2007
    Lancashire
    What HU did you originally have, DELTA CC?
    Your car is too early not to have both +v feeds, double check the pinout on the old HU.
    These links may help:
    http://www.audiworld.com/tech/elec70.shtml
    http://omgili.com/jmp/jHIAmI4hxg9LI....ytTyCDhyO.L2ns-
  3. Re: aftermarket stereo help needed asap
    Sep 2009
    lanark, scotland
    not sure of previous hu m afraid, stereo was stolen fom car and cant rememer
  4. Re: aftermarket stereo help needed asap
    Apr 2007
    Lancashire
    This list of pinouts for Audi head units may be of use.
    It is most likely the Delta CC on a 96 car.
    http://elsegra.com/Car%20pinouts/Audi.htm
  5. Re: aftermarket stereo help needed asap
    Sep 2009
    lanark, scotland
    yea i think its the delta cc but what difference will this make?
    thanks btw
  6. Re: aftermarket stereo help needed asap
    Apr 2007
    Lancashire
    With the correct pinout you can check if your battery and switched feeds are correctly wired into the HU, you will notice some do not even have a both feeds.
    You can also identify the anti-theft wire in the original connector, and ground it on the back of your HU.
    If you are still having no joy, i would wire into alternate batt & switched power sources from behind the dash, maybe routing wires to an unused bit of the nearby fusebox.
  1. Aftermarket Stereo
    By Tazdevil1977 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-09-2009, 07:20 PM
  2. Aftermarket Stereo for Newbie
    By davyb69 in forum Audi A3 - Archive Topics
    Last Post: 23-04-2008, 12:36 AM
  3. Symphony Stereo Code & Radio Fault
    By SimonVindec in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-03-2008, 02:42 AM
  4. Audi Avant A4 Symphony Stereo Radio failure
    By SimonVindec in forum New Member Introductions
    Last Post: 19-03-2008, 02:15 AM
  5. Help needed with aftermarket stereo install
    By frankieboy in forum Bora - 1998 - 2005
    Last Post: 18-07-2007, 02:40 PM
