Thread: Handbrake seized on :-(
  1. Handbrake seized on :-(
    "Duh" time. I was out in the "spare" car Passat 1996 TD about a month ago then parked it in the garage. Today I want to take it for a run - can't even get it out of the garage - it drags it's sorry rear end along the garage floor as the rear brake is seized on. I never leave the handbrake on overnight. Ever. Except that wet day a month ago.
    OK I have tried going back and forward a foot or so but the rear end just rises up on the suspension and drags the wheel along the garage floor until I can smell clutch. Fortunately it is the side I can get access to.
    What's the best solution guys? OD
  2. Re: Handbrake seized on :-(
    Norfolk
    Have you got rear drums or discs. If you have drums you can jack up that corner and belt the wheel with a big hammer and a block of wood, as long as it's a steel wheel. Hit just outside the wheel nuts. That should free it enough to move it. Don't do this with discs.
  3. Re: Handbrake seized on :-(
    Quote Originally Posted by martin1810 View Post
    Thanks Martin,
    I've got drums and steel wheels - I'll try tapping 5 or 6 bells out of it and let you all know how I fare. Cheers, OD
  4. Re: Handbrake seized on :-(
    Yup - worked a treat after removing the road wheels. Banged away with a "domestic" claw hammer at different points on the drum and after about 20 bangs it started to "ring" like a bell as the shoes came away and stopped damping the noise.
    Thanks. OD
  5. Re: Handbrake seized on :-(
    Chipped2 Guest
    The rear brake shoes on this mode each sit on three round black nylon ? bushes that clip into the pressed steel backing plate allowing the shoes to move slightly when the brakes are applied. Each brake shoe rests on 3 bushes, on at each end and a middle one.
    Eventually the surface of these bushes develops a curved wear channel that will not allow the shoes to return easily to the off position. These bushes are not available as a spare part and you will have to order new backing plates and usually new bolts too.
    You can either, carefully remove each one and sand off the surface of the bushes to give a smooth flat surface again, half a mill is usually enough or as a temporary measure turn each one through 90 degrees. It simply puts off the evil day when you can order replacement backing plates and either transfer the new bushes to the original plates or as stated, replace the whole plates.
    If you have a small lathe and can turn nylon bar it is possible to make new ones securing with stainless spring star washers. Only attempt if confident & competent !
  6. Re: Handbrake seized on :-(
    Chipped2 - thank you for that. As you will see in the post above, I hit the drum with a hammer in the time-honoured manner and that sorted it on this occasion; if it recurs I will try your method. OD
  1. Ever wondered what happens when you push the handbrake button whilst driving ?
    By carl s in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-03-2010, 07:39 PM
  2. Passat Electronic Handbrake (doomsday scenario)
    By meoman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-06-2009, 05:52 PM
  3. Question Reversing lights come on/flicker with handbrake
    By Hellsteeth in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-05-2009, 10:26 AM
  4. handbrake lever
    By futsysmids in forum 80 - 90
    Last Post: 17-02-2008, 11:39 AM
  5. Passat Electronic Handbrake Problems
    By wildinthecountry in forum Passat - Archive Topics
    Last Post: 08-10-2006, 05:39 PM
