Thread: Cambelt Change - Audi A4 2004 TDI SE (130)
  1. Exclamation
    Dec 2006
    And here are the pictures of the water pump which caused all this hassle..!!
    RicKT
    Oct 2005
    Lutterworth
    Just to chip in here :
    I changed the cambelt on my sons PD130 at 126K over the weekend.
    The old belt was like new and the tensioners, roller and pump, which were all changed , were in fine fettle.
    To make life easier I pulled the top and bottom rad hoses to allow the front to be swung out at about 45 degrees, and would recommend this to anyone.
    The crank ribbed belt pully bolts are a pain, too soft and too tight. Make sure you have a really good quality 6mm key else you will chew them. I was left with one that I do not think I will get out again.....
    Other than that, it was a breeze.....
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
    Apr 2007
    Thanks for that guys....
    I've just phoned the dealer & have been advised that the cambelt kit consists of belt, roller & tensioner... I asked about the water pump & was advised that this particular model does not need it changing, but after reading the thread, I've decided to get it changed anyway.
    Also ordered the V-belt AKA ribbed belt....
    Jon
  1. How do i change the pollen filter 2004 Golf 2.0 TDI
    By daveaustin in forum Archive posts
    Last Post: 17-04-2007, 11:37 PM
  2. How do i change the fuel filter 2004 Golf 2.0 TDI
    Last Post: 17-04-2007, 11:36 PM
  3. How do i change the oil filter 2004 Golf 2.0 TDI
    Last Post: 17-04-2007, 11:34 PM
  4. cambelt change 2.5v6 tdi
    By mer in forum Passat - Archive Topics
    Last Post: 30-12-2006, 06:20 PM
  5. cambelt change on tdi
    By HOVISVW in forum Chat - Completely Off Topic
    Last Post: 14-10-2006, 11:23 AM
