Thread: air con smelling !!
  1. air con smelling !!
    Feb 2007
    as title suggest my air con smells BAD for first 5-10 mins of a run then appears to go.Either that or i get used to smell !!Is there any thing i can change ie filter or is it straight to specialist ??
    Dec 2006
    You can change the pollen filter.. but it wont make much difference i bet if its just when you put the air-con on..
    I would sugguest getting the system serviced and cleaning..
    RicKT
    Feb 2007
    thanks Rick ,but its not My aura ! specifically the aura of cat !
  4. Wink Just done my A4
    Apr 2007
    Got a can of Comma Air Con cleaner from Halfords - £12. worked a treat. Kills all the fungii and bugs that have been breeding in your air con ducts!!
    Dec 2006
    Éire
    ___________________________________
    Previously: 03 A4 1.9TDI , 05 A4 2.0TDI S-Line, 05 A6 2.7TDI S-Line Quattro , 06 A4 2.0TDI S-Line Avant, 08 2.0 TDI MK5 GOLF GT SPORT TDI 170 DSG, 10 A6 2.0 LE MANS 170, 19 G30 520d MSport
    Now: waiting
    Mar 2007
    Lancashire
    Why should bugs and fungi bread in an air conditioning unit? Why do some people have it for years and have no problem.
    Apr 2007
    You have to use it regularly otherwise the warmth and moisture encourage breeding when the system is idle. Once you have a certain amount they won't go away without chemical warfare.
