Thread: Audi A6 Fault Diagnosis Help...
  1. Audi A6 Fault Diagnosis Help...
    Hiya,
    I've got a 2003 Audi A6 1.8t (petrol), AWT engine. About a year ago it developed a mis fire, along with the engine management light illuminating. The AA came out, and diagnosed the fault as a coil pack failure - so I replaced that coil, and the other 3. Everything was fine.
    Fast forward to the past couple of weeks - the engine management light has come on again - took it to a local garage (useless place, now I know) and they said that it was an 'unknown fault' - cleared the memory, and its back (no suprise). A mate of mine works for the AA, and he plugged his computer into it, and the following came up:
    Fault code P0353, Ignition coil C, Primary/Secondary Circuits.
    A bit of digging on the internet shows it might be a circuit malfunction, and the DTC (whatever that is?) is 16737.
    He cleared the code - checked the plug gaps (all ok), and all the coil pack connectors (all ok). The light then came back on.
    The car drives fine - no misfiring, fuel consumption is the same, starts and runs great. The problem is I don't really understand what the fault is - would anyone on here be able to suggest what it might be, and how I might be able to fix it?
    Thanks in advance,
    Biker_billy.
  2. Re: Audi A6 Fault Diagnosis Help...
    Jan 2009
    towcester northants
    just looked at elsa workshop manual and this fault code isnt listed
    you can check wiring from ecu to coils
    also check injectors
  3. Re: Audi A6 Fault Diagnosis Help...
    Apr 2009
    Just found this:
    http://forums.vwvortex.com/zerothread?id=3869028
    * VW DTC 16737 (P0353) - Ignition Coil (C) Cylinder 3 Primary / Secondary Circuit Malfunction
    Might be of some help, let us know how you get on.
  4. Re: Audi A6 Fault Diagnosis Help...
    Thanks for the replies. I'll think I'll give the wiring a good check over, on the weekend to see if I can find the fault.
    Just a question tho - will I need to clear the fault codes to clear the engine management light on the dash? - Or will it turn itself off when the fault disappears?
    Thanks,
    BB
  5. Re: Audi A6 Fault Diagnosis Help...
    Apr 2009
    I am pretty sure the engine management light will go out when you find and cure the fault, however the fault code will stay stored in memory until cleared.
  1. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  2. The new generation Audi A3
    Last Post: 28-04-2008, 07:04 PM
  3. Audi set for 12th record-breaking year in a row
    Last Post: 31-07-2007, 08:34 PM
  4. Prime London location for world's largest Audi centre
    Last Post: 23-09-2006, 01:38 PM
  5. At home on all roads and tracks - Audi A6 allroad quattro
    Last Post: 05-03-2006, 07:53 PM
