Thread: Dip stick...
  1. Dip stick...
    Sep 2009
    north shields, tyne and wear
    Hi was just checking my oil level on my audi a4 petrol 1997 and the dipstick just sits on top of the housing for it. When the engine is running you can see the dipstick shaking about. All of the previous cars I've had the dip sticks had some resistance to them when pulling them out. Is this normal for the model I have
  2. Re: Dip stick...
    chrismaher2007 Guest
    ive a 2000 and the dipstick sits firmly in with no shaking. in fact mine broke before by having to pull it out. its tightly in there
  3. Re: Dip stick...
    132 Post(s)
    1980 Post(s)
    The dip stick guide funnel is broken. For a 1.8 20v ADR engine the part number is 050 103 663 and from an Audi dealer they cost about £2. Be very wary of cheap replacements as they are a terrible fit and often snap as you try to push them down. When removing the old one, a ring of plastic often stays inside the metal tube and you will need to carefully fish it out to allow the new tube to click into place.
  4. Re: Dip stick...
    Sep 2009
    thanks for the help, off to audi in the morning
  5. Re: Dip stick...
    Sep 2009
    uk
    Just had the same problem with mine as I had oil spilling over. Got a new dipstick guide from Audi for £2.30 problem solved.
  1. Dip Stick!
    By Foringo in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-03-2014, 09:57 PM
  2. passat dip stick
    By gpaul in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-08-2009, 05:02 PM
  3. Question Passat brake fluid cap and dip stick required.
    By matt111074 in forum Early Passat Forum - Pre 97
    Last Post: 25-04-2009, 01:39 PM
  4. Gear stick question
    By dorgan in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 14-05-2008, 08:34 PM
  5. Audi 2.8 auto dip stick
    By roogy in forum Chat - Anything with wheels
    Last Post: 27-04-2007, 09:05 PM
