Thread: BNS 5.0 Problem
Results 1 to 10 of 11
  1. Exclamation BNS 5.0 Problem
    Apr 2007
    Hello,
    My BNS 5.0 has the IPOD connected through the glove box and i have read through the manual and it says that the tracks on the stereo should come up with the name as it does on the IPOD. The BNS 5.0 only comes up with tracks 1 to 99.
    Any advice????
  2. Re: BNS 5.0 Problem
    May 2007
    knee deep in clunge
    14 Post(s)
    You have misread as there is no function for id tags, go to itune's and format your play list 1 to 5 albums etc and 6 on the go as the ipod plays as a cd player.I have covered this many times if you fit dension 300/100 this will display id tags but the audi factory fit and retro fit option does not support id tags.The radio can display them but the ipod connection runs via a cd emulator without id tag transfer supported software
  3. Re: BNS 5.0 Problem
    Apr 2007
    Thats not very good. Can the RNS-E display track names? And if so is it a straight swap?? One out, one in???
  4. Re: BNS 5.0 Problem
    May 2007
    knee deep in clunge
    14 Post(s)
    Audi ipod kit no for id tags and slight mod for the k wire for rnse.Dension kit allows id tags
  5. Re: BNS 5.0 Problem
    Apr 2007
    Is the mod for the K wire much work??? How much is it for the dension kit??
  6. Re: BNS 5.0 Problem
    May 2008
    The Dension wont display track info on the RNS-E screen though will it? It only displays it in the DIS I thought? (As long as you get the right Dension kit - not all display track info)
    K-wire is easy to move, 5 minutes work.
  7. Re: BNS 5.0 Problem
    May 2007
    knee deep in clunge
    14 Post(s)
    Yes the dension kit only displays id tags via the dis
  8. Re: BNS 5.0 Problem
    Apr 2007
    So if i do a straight swap with the RNS and change the K wire, the system should still work the Bluetooth HAnds free also???
  9. Re: BNS 5.0 Problem
    May 2008
    Yes but you should also ensure its all coded correctly with VAG-COM.
  10. Re: BNS 5.0 Problem
    May 2007
    knee deep in clunge
    14 Post(s)
    You need vag com for code changes and adaption changes in address 77,56 and 17.K wire is the diagnostic link
  1. Crasher can you help? mk3 TDi problem
    By chackday in forum Golf MK3 - 1993 - 1999
    Last Post: 08-05-2008, 08:50 PM
  2. Power problem turbo not working
    By marfitzd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-05-2008, 11:04 AM
  3. Advice about poss recurring problem
    By chicka in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2008, 05:58 PM
  4. Mk3 Golf CL Tdi - Cutting Out Problem
    By spenhog in forum Golf MK3 - 1993 - 1999
    Last Post: 07-12-2007, 05:46 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
