Thread: Wheel Alignment, garage caused damage
  1. Wheel Alignment, garage caused damage
    May 2009
    Ayrshire UK
    1994 passat estate 1.9 1z
    Had track rod ends replaced at a small garage who we use often and have never had problems with, then took the car to a larger garage to have alignment done.The car pulls badly to the left now which it never did before the alingment. After a few days a clunk started so we had a look under the car, there was grease splattered everywhere from the cv outer joint gaiter, the steering rack gaiter has damage too. We contacted the garage who have offered to replace the gaiters (the mechanic said he probably turned the torch up too high) What other components should they be responsible for?
    Thanks,
    Mandie.
  2. Re: Wheel Alignment, garage caused damage
    Dec 2009
    hounslow
    if you had the trak rods done ,ask them y would thay need to use the torch.
  1. Court Hearing - Information required...
    By motyourcar in forum Chat - Anything with wheels
    Last Post: 17-08-2011, 09:31 PM
  2. Question Wheel bearing noise not a Wheel bearing
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2009, 10:31 PM
  3. Wishbone Front / Rear Axle Bush which brand
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 23-05-2009, 12:27 AM
  4. MK4 Repair List - DIY or Garage - Help
    By Red_Tekk in forum Polo - Derby - Lupo - Fox
    Last Post: 13-05-2009, 11:00 PM
  5. Steel wheel question?
    By Huffy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-04-2008, 05:52 PM
