Thread: A4 Avant 1997 Overheating
Results 1 to 10 of 10
  1. A4 Avant 1997 Overheating
    Aug 2006
    Coming back on the motorway yestarday , my A4 was sounding a little odd. Sounded like there was extra wind noise when the speed was over 60 (this might not be related to the overheating problem at all).
    When I got back into town the temperature went up and up until the temperature warning light came on.
    2 minutes later I was home and there was no noise from the fan and the temp light was still on.
    Question is, where do I start. Do I drive the car 9 miles on country roads to my usual garage, taking the chance that it might overheat and damage the engine, or do I call a breakdown truck. Or do I try and fix it myself.
    I've got fairly basic mechanical skills - I'm comfortable with standard servicing-type jobs but is this a job that I should even try to attempt myself?
    Apr 2007
    An easy 9 miles drive from a cold engine shouldn't put any extra strain on the engine, I would have thought it should be fine to drive that short distance.
    I'd say check some fuses/relays on the fan but if temp went up at 60mph then perhaps the water's not circulating - you should be able to see it coming out of the pipe into the tank....
    Mar 2007
    Cornwall
    My engine reaches full temperature within 3 miles from cold - I wouldn't risk driving another 6 miles with suspect cooling unless the engine had cooled down completely.
    What is the guage indicating when this happens? Does it loose water?
    From what you've described, I'd guess the water pump impeller is slipping or broken up. You can verify this by removing the hose comming off the pump and feeling if the impeller is in place and firm on the shaft.
    Guy
    Aug 2006
    Thanks - I took the chance and drove the car to the garage this morning. Got there just as the guage was starting to soar (but it never got to the point where the temp light came on).
    When there are so many variables - head gasket, radiator, fan, water pump, relays, sensors etc, I'd rather just pay a garage to fix it and hopefully have it back in a couple of days. If I tried to investigate all these things myself I'd be lucky to have it on the road again by July.
    May 2007
    Leeds
    I do 60 miles per day 5 days a week, without the viscous fan! I had to take it out, the ball bearing died. A Diesel like yours does not usually overheat. I believe you had a minor problem, like someone suggested, the water pump, etc. Let us know what the problem was when you have it fixed.
    ex Audi 1.9 TDI 1997, AHU
    Audi 1.8 Petrol/LPG
    Audi 1.9TDI AFN Quattro
    norn iron
    my 98 tdi has never risen above 75 usually sits at 65 unless i give it a really hard time.ive got a tunning box 75 max!!!my wifes car sits at 90 all day every day also my oil temp gauge never goes over the 65 mark,)wife doesnt have one so i cant compare) any ideas
    May 2007
    Leeds
    You have a temperature gauge that sends data to the dash board and another one that sends it to the ECU.
    The one that you see does not MATTER in terms of how your engine is running. Ignore it if it does not bother you, as long as you are sure that 75 is not the "real" temperature. That temp. sender is a weak point for many of them. IT is easy enough to replace it if you really want to. If your thermostat is OK, temperature should raise to close to 90, even under normal driving conditions.
    Audi 1.8 Petrol/LPG
    Mar 2007
    Cornwall
    Quote Originally Posted by stubbsy View Post
    Either the sender for your dash guage is failing or your thermostat is stuck open. The latter will result in the engine running at less than it's optimum temperature, so you should check.
    Guy
    norn iron
    Quote Originally Posted by guyg View Post
    Guy
    all sorted changed the thermostat no sits at 90 all the time but heres one for you,the oil temp now sits at 85/90 all the time too now work that one out,i dont care all gauges now read as they are supposed to
    Mar 2007
    Cornwall
    If the thermostat was stuck open, the engine will be over-cooled, which will result in lower oil temperature as well as everything else. You might even notice a slight improvemet in fuel consumption now.
    Cheers,
    Guy
  1. Overheating
    By Dacabbie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-04-2007, 10:32 PM
  2. 1997 golf 1.9TD GL overheating problem
    By wyndym in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 31-01-2007, 03:23 PM
  3. A3 1.6 overheating ?
    By AdamG in forum Audi A3 - Archive Topics
    Last Post: 12-01-2007, 01:48 AM
  4. A6 1.8T overheating
    By Grommit in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-12-2006, 08:29 AM
  5. Overheating? - Maybe
    By chris green in forum 80 - 90
    Last Post: 03-07-2006, 04:20 PM
