Thread: ABS warning light
  1. ABS warning light
    Dec 2006
    The warning light for the ABS has recently come on in my 1999 T-reg A6 1.8TSE manual.
    I was driving along and then there are three loud beeps (like when petrol gets low), and a big flashing exclamation mark appears on the dash screen. At the same time, the orange ABS warning light comes on. It will normally carry on doing this until I turn the engine off. The brakes work ok during this time, although obviously I've not needed the ABS since then.
    Each time I turn the engine on, it's usually a few minutes before this warning light comes back on.
    I imagine this is probably a faulty sensor, but how would I go about getting this fixed? The Audi dealership want £105/hr just to diagnose the problem, while it is in for a service next week! I told them to just do the oil service and I'll worry about the ABS.
    Any suggestions would be appreciated!
    Sam
    Mar 2007
    Plymouth Devon
    Hi Sam,
    I have recently had this very problem. 1999 Audi A6 1.8T SE. You will need to have a computer diagnostic conducted. I paid £40 for this from a local garage. This will give them an idea as to the problem. It could be a faulty wheel sensor or as in my case the ABS Modulator. Audi quote £1400 to replace this part!! I shopped around on the internet and used www.ecu-testing.com for a reconditioned part. £200 plus VAT. They charge £60 extra until they receive your duff modulator and this £60 is returned. You can send your part (if your happy to drive without the modulator) have it repaired for £100. Either way alot less than Audi. They also give you a 2 year warranty (also better than Audi).
    Hope this helps
    Steve
    Mar 2007
    I have recently done the same as Sam, its quite a saving using ECU.
  1. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
  2. DIS Brake Fluid Warning with ABS warning light
    By radar1022 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-04-2007, 10:42 AM
  3. Brake fluid warning light with ABS light
    Last Post: 02-04-2007, 03:28 PM
  4. ECU Warning Light
    By Gavin78 in forum Passat - Archive Topics
    Last Post: 02-04-2007, 12:51 PM
  5. Oil warning light
    By Stue in forum Polo - Derby - Lupo - Fox
    Last Post: 10-10-2006, 09:16 PM
