Thread: A6 gearbox whine
Results 1 to 10 of 17
  1. A6 gearbox whine
    Feb 2007
    My brother recently picked up an 02 Audi A6 2.5 TDi cheaply at auction. It has an Audi FSH and has done 105K. Car runs beautifully but has a slight whine from the manual gearbox at higher revs. One suggestion from a mechanic friend is that it is possibly a bearing problem in the gearbox diff? Any thoughts or opinions?
    Dave
    Is it 2 wheel drive or 4 wheel drive?
    Feb 2007
    It's a 2 wheel drive 6 speed
    Mar 2007
    Shropshire
    I get this whine at low revs but i think its normal as ive covered 89K. May invest in a gearbox fluid change.
    -Desdesigner
  5. Re: A6 gearbox whine
    Aug 2007
    Hi guys
    Get your gearboxes checked soon, DON'T leave it, I've just bought a Passat tdi sport 6 speed with the same fault.
    It was the Pinion bearing on mine which is apparently VERY common on the 6 speed box. I had the pinion bearing and the other bearing on the same shaft replaced.
    If left it could scrap the crown wheel & pinion which could be very expensive.
    The diff can be removed & checked in-situ on this box, so it may be a cheap way to eliminate it, but if you leave it, a refurb of just the bearings costs around £700, then if the gears or crownwheel and pinion are knackered, it could cost you a fortune, if that's happened, you may as well source a new box.
    The guy who repaired mine said I'd caught it in the nick of time, and there was only a slight noise in 3rd, 4th, 5th & 6th.
    I hope this is of some use to you, I did a lot of research on this subject and just hope this info may save you some money
    Ade
  6. Re: A6 gearbox whine
    Sep 2008
    Chichester
    I know noises are really difficult to describe but I have a "whirring" noise on my car, which seems to be related to road speed. It's a 6 speed manual 1.9 TDI with 76K and I'm worried I may have this bearing problem. It's not a whine as such, more like someone blowing a kazoo
    The noise is only just noticeable when driving over about 40mph and is most noticeable when slowing down, say to a junction with the radio off. Dipping the clutch doesn't affect it and neither does road surface as far as I can tell.
    Can anyone who's had this problem confirm if what I have sounds (pardon the pun) like the same problem??
    Eeyore
    A6 Avant 2.0 TDIe 2009 (Facelift)
    Not worth starting anything now...."
  7. Re: A6 gearbox whine
    Feb 2007
    That does sound similar to the sound that I was getting on my 6 speed A6 and unfortunately this was due to the fault described above. Definitely worth getting it checked I would say,
    Dave
  8. Re: A6 gearbox whine
    Sep 2008
    Chichester
    OK, well I jacked up the car this morning and spun the front wheels out of gear. There's nothing major but there is a very slight click/notchiness in some places as you turn the wheel around. No noise from the wheel area itself.
    Is this normal or should I be getting worried
    How much should the pinion bearing work cost if it is required??
    Eeyore
  9. Re: A6 gearbox whine
    Are you sure this is not a wheel bearing giving notice, does the noise change with direction of steering as the wheel loads up. Regards Peter
  10. Re: A6 gearbox whine
    Sep 2008
    Chichester
    No change of noise with wheel direction.
    Last weekend I fitted a set of 18" wheels, which I've just swapped back temporarily to the original 17s. If I listen really carefully I can just make out a similar noise but it is much quieter. With the 18s on it's quite prominent.
    I'm thinking tyre noise then (as much as it doesn't sound like it)? Surely if this were gearbox/diff the wheels wouldn't affect it?
    Eeyore
  1. Transmission Whine
    By RN Colley in forum Passat - Archive Topics
    Last Post: 04-10-2007, 09:57 AM
  2. Audi Cabrio Whine
    By andrewaudi in forum 80 - 90
    Last Post: 23-08-2007, 11:45 PM
  3. Power steering whine
    By renamecor in forum Archive posts
    Last Post: 06-08-2007, 09:40 AM
  4. A4 whirr/whine
    By Fray Bentos in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2007, 01:51 PM
  5. mark 4 golf engine whine
    By steveh2507 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-01-2007, 12:13 AM
