Thread: Lots of smoke and lack of power
  1. Lots of smoke and lack of power
    Nov 2006
    derbyshire
    Hey, got a passat 1999 110 AFN with 150k done. Am i right in thinking that this fault would be the cause of a faulty mass airflow sensor. If not, what else could cause this problem. Cheers bud!
  2. Re: Lots of smoke and lack of power
    Defect boost hose
  3. Re: Lots of smoke and lack of power
    Nov 2006
    derbyshire
    getting over a pit tomorrow, will have a good look round.
  4. Re: Lots of smoke and lack of power
    Nov 2006
    derbyshire
    Ok, had a good once over. All turbo hoses ok, turbo ok, air cleaner clean and intercooler ok. Been running it to work and back for a week (normally the wife drives this car) on the motorway and the smoking seems to be clearing but she still is down on power. No fault codes are stored in ecu's. Only two things left that I think is that the cat is failing and getting clogged up with all the short distance drives and/or MAF sensor going **** up. Which is the most common on the AFN engine to fail or am i barking up the wrong tree. Ta!
  5. Re: Lots of smoke and lack of power
    Norfolk
    MAF sometimes fails without giving a code. Trouble is you have to replace it to find out and it's not cheap.
  6. Re: Lots of smoke and lack of power
    Nov 2006
    derbyshire
    Changed maf sensor which did nowt. only thing left is a clogged up cat me thinks? any more ideas?
  7. Re: Lots of smoke and lack of power
    Norfolk
    Temperature sensor. If it tells the ecu the engine is cold it will over fuel. This won't throw a code if the signal is within spec.
  1. A6 1.9 Tdi Lack Of Power
    By senator in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-01-2010, 12:47 PM
  2. Black smoke, excessive fuel consumption and lack of power.
    By HomerSimpson in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-09-2009, 07:20 PM
  3. Please Help white smoke and lack of power passat tdi
    By plasticcouch81 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-08-2009, 10:04 PM
  4. TDI 130 lack of power
    By Michelin in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2007, 03:07 PM
  5. black smoke no power help
    By minty0_10 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-11-2007, 12:34 AM
