Thread: Colour DIS Retrofit
  1. Colour DIS Retrofit
    Jan 2009
    Is it possible to retrofit the colour DIS?
  2. Re: Colour DIS Retrofit
    May 2008
    Yes, you need to replace the whole instrument cluster though.
  3. Re: Colour DIS Retrofit
    Jan 2009
    So if i got a colour DIS instrument cluster, it should just swap over with same plugs and connections?
  4. Re: Colour DIS Retrofit
    May 2008
    Yes it will, although you will of course need to get the immobiliser reprogrammed or the car wont start.
  5. Re: Colour DIS Retrofit
    Jan 2009
    im assuming you could use vagcom to reprogramme? Also do you know how to reprogramme?
    Thanks Issac for the help.
  6. Re: Colour DIS Retrofit
    May 2008
    Quote Originally Posted by shahid8850 View Post
    You can only use VAG-COM if you know your cars SKC (secret key code) you need this number to access the immobiliser. VAG-COM cannot retrieve it for you. If you havent got it then it needs to go to a dealer or someone with the equipment to get it.
    If you have/or get the SKC then programming is easy, Follow the guide from www.ross-tech.com
  1. Question How popular was Colour DIS an Option?
    By kodkod.84 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-07-2009, 07:38 AM
  2. DIS stalk retrofit - question?
    By Xizor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-06-2009, 10:07 PM
  3. DIS setup question
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-05-2009, 09:49 PM
  4. Dis Retrofit
    By rigsby29 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-07-2008, 11:58 AM
  5. replacing monchrome (red) DIS with the colour version
    By dave9_3 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 12-02-2008, 08:27 PM
