Thread: vagcom lead
  1. vagcom lead
    Aug 2009
    Stoke
    Ok im about to get a vagcom lead, are there any ones i should avoid buying? I think ill only need the basic 409 one, with this i intend to read and erase faults and reprogramme a key, will i have any issues ?
  2. Re: vagcom lead
    Jun 2007
    There was a period in 98/99 when the comms with OBD was different and a Vagcom cable will not work. If you look at the connector the wider side of the moulding should have sockets in pins 2,4,5,7 and in the narrow row 10,15, and 16. If this is not the case a straight cable will not communicate at all and the correct cable/adaptor will cost you circa £260 plus vat. Regards Peter
  3. Re: vagcom lead
    Aug 2009
    Stoke
    FFS why are these cars so bloody difficult. Where will i find the connectors Peter ?
    Regards
  4. Re: vagcom lead
    Jun 2007
    Right of the steering wheel under the dash facing down. Regards Peter
  5. Re: vagcom lead
    Aug 2009
    Stoke
    thanks very much peter
  1. How To Retro fitting VW Aux-in Lead Golf MK5
    By Kevster140 in forum In Car Entertainment
    Last Post: 02-02-2023, 11:50 PM
  2. COMPLETED: Vagcom 409 Compatible USB Cable Group Buy!
    By Eshrules in forum Site Sponsors - Current Group Buys
    Last Post: 03-07-2008, 03:22 PM
  3. Vag diagnostic tools. A summary.
    By Ben in forum VCDS - General Questions
    Last Post: 16-03-2008, 10:22 PM
  4. Vag Com problems with B6 Audi A4 (usb KKL lead)
    By Amit in forum VCDS - General Questions
    Last Post: 17-02-2008, 12:17 AM
  5. Which VagCom lead for 1999 passat
    By bolov in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-05-2007, 07:15 PM
