Thread: B6 2006 Passat
  1. B6 2006 Passat
    Apr 2009
    Glasgow
    I have an older copy of VAGCOM software from the 311.xx series. Is this safe to use with a 2006 Passat? I remember a warning message stating that in certain models/years the user could damage a controller simply by scanning it! I think this related to Airbags.
    I don't want to pay for an updated version of software if the older version will do. I just want to edit a few convienece features and check fault codes should they ever arise.
    Also on the VAGCOM website you can buy HEX, Key (KII) or Micro-CAN. I have a USB to serial adpater which I used with my 98 Polo. Is the connection on the passat not the same?
    Thanks for any help offered.
    A
  2. Re: B6 2006 Passat
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by aperson View Post
    A
    Short answer is no. 2005 onwards Passats use CANBUS, so therefore you'd need to upgrade to a CAN enabled version.
    http://www.ross-tech.com/vag-com/car...ns/passat.html
    HTH
    Nothing to see here, move along..
  3. Re: B6 2006 Passat
    Apr 2009
    Glasgow
    Quote Originally Posted by Hex69 View Post
    HTH
    Thanks HTH.
    Does this mean I can still use the same cable but I just need a newer version of the software? What version of software would be suitable as my friend has a new version...
    A
  4. Re: B6 2006 Passat
    Mar 2008
    Just Cumbria now.
    Thanks HTH.
    A
    Anything over Release 607 should be fine, latest version is 908.
    Hex
  5. Re: B6 2006 Passat
    Apr 2009
    Glasgow
    Just to confirm... The cable I currently have, which works with my 98 Polo, is ok to use with software 607 and above?
    Thanks again.
  6. Re: B6 2006 Passat
    Aug 2008
    no your cheap cable will not work
    you need a can enabled cable and vcds 908
    can enabled cables are only availiable from ross tech and there distributors
    hope this helps
    paul
  7. Re: B6 2006 Passat
    Magdeburg, Germany
    Directly on the first VAG-COM/VCDS page in our online shop system you'll find the US & Canada Application Charts for information regarding which interface will work with your north American model and the typical modules supported. Additionally there is the VCDS World Spec Compatibility Charts for all non-US models.
    That should give you straight answers what systems support which models and which are best for your specific vehicle. However, to sum things up - if you want to be ready for your future VW/Audi and be able to work on other cars than your 2006 VW Passat (3C) the HEX+CAN systems will be optimal. If its just your 2006 VW Passat (3C) you plan working on, then the Micro-CAN systems will do the trick.
    Sebastian @ www.Ross-Tech.com
  1. My first impressions of my GT TDi Golf
    By james_tiger_woo in forum Golf MK6 - 2009 - 2013
    Last Post: 30-06-2009, 05:42 PM
  2. Passat B6 recall
    By John Robertson in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-04-2008, 09:46 PM
  3. Buying checklist for a DSG B6 Passat
    By Kaiser2000 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 01-03-2008, 03:11 PM
  4. Replies: 0
    Last Post: 10-11-2007, 08:05 PM
  5. Auto1 Award: The Passat is Europe’s Number One
    Last Post: 07-03-2006, 08:56 PM
