Thread: Chrome door trim removal
Results 1 to 9 of 9
  1. Chrome door trim removal
    Aug 2009
    United Kingdom
    Hi Guys
    Looked in the Haynes manual but surprise surprise doesn't tell you how to remove the trims.
    I have a 2005 1.9 Highline with the chrome trims along the doors, are they just stuck on if so what sort of job is it to remove them I have a feeling they will get a bit damaged on removal.
    Just really want to know if they are stuck on or held by clips.
  2. Re: Chrome door trim removal
    Aug 2009
    United Kingdom
    Quote Originally Posted by Norman vwp View Post
    Hi Guys
    Anyone out there.
  3. Re: Chrome door trim removal
    Norfolk
    I believe they are the same as the other trims. Glued on with central lugs to push in and line them up. To remove heat carefully with hot air blower. You can't really refit them as they get ruined taking them off.
  4. Re: Chrome door trim removal
    Jun 2006
    UK, Mids
    I agree, budget for replacements as they stretch and bend.
    Audi A8 - 2015 - 3.0TDI
  5. Re: Chrome door trim removal
    Aug 2009
    United Kingdom
    Thanks Guys
    I will try and get a new one before I remove the old one then.
    Norman
  6. Re: Chrome door trim removal
    7 Post(s)
    Why are you removing them?
    A de-chrome project or are they milky ?
    If they are milky, then they will polish up if you use the right stuff.
    I had this on my old B5.5 Passat and on my current A6, both had milky chrome (in fact it is aluminium) and is a very common problem if acidic cleaners are used.
    Polishing them up takes a fair bit of effort but is certainly easier and cheaper than renewing them.
    Normal polishes will not touch it though, you need to use (like I did) something like Faracla G6 then G3 then Autosol. And a good bit of elbow grease.
    Once brought back to shiny, regular waxing will maintain them that way.
  7. Re: Chrome door trim removal
    Aug 2007
    The centre trim on the door costs nearly £50 from VW, they come as the trim and moulding (which comes unpainted).
  8. Re: Chrome door trim removal
    Aug 2009
    United Kingdom
    Quote Originally Posted by creedxup View Post
    OUCH!
  9. Re: Chrome door trim removal
    Aug 2009
    United Kingdom
    Quote Originally Posted by BigCol View Post
    Thanks BigCol
    I will give that a try
    Just tried it and it works a treat that will keep me busy when I have some spare time
  1. Cup holder w/ chrome trim?
    By Turbokiisseli in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2009, 08:40 AM
  2. Chrome exhausts
    By scottishbud in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-06-2009, 05:19 PM
  3. A6 - Chrome trim on doors
    By JimC64 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-05-2009, 04:03 PM
  4. Chrome grille pack removal
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-03-2008, 11:44 AM
  5. Quite simply ... black or chrome?!
    By rick_s in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-05-2007, 07:28 PM
