Thread: 2.5 TDI misfire/hesitation
  1. 2.5 TDI misfire/hesitation
    slarti Guest
    Hopefully someone on here will be able to help me diagnose what's wrong with my car.
    The car is a 1998 A4 2.5 V6 TDi quattro. I have recently noticed a misfire or hesitation when accelerating at around 2500-3250RPM with around half to three quarters thottle. When it comes in, it gives a judder through the car. To start with it was so slight that I thought it was just bumps in the road but now it's got much worse and I have to anticipate when it will happen and adjust how hard I'm accelerating and my pressure on the accelerator to minimise it.
    Also, a while ago I notice that the speedo was reading 0 when I was coming to the end of a journey. Next time I drove it, it was fine. Since then it intermittanly drops to 0 or waves around on the dial. I have noticed that when it drops to 0 the fuel guage waves around a bit when going round corners or accelerating/braking.
    I don't know if the two issues are related.
    I ran a fault code scan with vag-com and the only one that came up was this:
    Address 01: Engine
    Controller: 8D0 907 401 B
    Component: 2.5l/4VT EDC G00SG D41
    Coding: 02003
    Shop #: WSC 06335
    1 Fault Found:
    00625 - Vehicle Speed Signal
    27-10 - Implausible Signal - Intermittent
    Readiness: N/A
    It sounds like this might explain the speedo problem but I can't find any references to what this fault might actually be.
    Sorry for the long post. Any suggestions or ideas welcome.
  2. Re: 2.5 TDI misfire/hesitation
    Sep 2009
    hull
    Hi there.. As regards to your misfire i have the same problem and have just found out that my no 1 injector is clogged so im going to try some injector cleaner first.
    Hope this helps as it might be worth checking your injectors.
  3. Re: 2.5 TDI misfire/hesitation
    Nov 2008
    folkestone.kent
    the speedo sensor does cause problems with the fuel gauge ,it a common fault it worth changing this first to see if it is responsible for your misfire fault,the ecu needs to see a speed signal as well as the instrument panel......
  4. Re: 2.5 TDI misfire/hesitation
    slarti Guest
    Thanks for the suggestions.
    Any idea where the speedo sensor is? I can't find any reference to it anywhere. What would it be called in the parts catalogue?
  5. Re: 2.5 TDI misfire/hesitation
    Nov 2008
    folkestone.kent
    vehicle speed sensor is on the gearbox,whats your engine and gearbox code,is it an auto box or manual ?
  6. Re: 2.5 TDI misfire/hesitation
    slarti Guest
    I'm not sure of the codes, I can find out this weekend.
    The engine is the 2.5 V6 TDi (I think its the 150bhp version) and the transmission is 6-speed manual quattro.
  1. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  2. Volkswagen launches new range of highly efficient golf models
    Last Post: 03-07-2009, 07:48 PM
  3. Replies: 0
  4. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  5. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
