Thread: camshaft cover
  1. camshaft cover
    Jul 2008
    Wales
    Hi there.
    How do you get the rear camshaft rubber cover off a 2.5 tdi afb engine, I want to do the timing. Dose it screw off, I have taken off all pipework around it for access, but it still wont budge!!!
  2. Re: camshaft cover
    london/ UK
    Dealer does dammage the cover... If you have a new one its ok but i do slacken the 2x11mm nuts that hold the end bearing then i pry it off with a csrewdriver. Smear a bit of grease on the cap prior re-fittinng then tighten the bearing sensibly. You will need to slacken all 10mm nuts holding the rocker cover as well to give enough room to lever the cover.
  3. Re: camshaft cover
    Jul 2008
    Wales
    Thanks, got it off
  1. How To Corroded Golf Mk2 GTi clutch bearing cover
    By Andrew Mcl in forum Golf MK2 - 1984 - 1992
    Last Post: 11-07-2009, 12:29 AM
  2. Fuel Tank Flap cover!
    By BLASTER in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-06-2009, 09:20 PM
  3. camshaft problem
    By audi-man in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-04-2009, 09:47 PM
  4. Question Avant B8 Load Bay Cover
    By timpe in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-03-2009, 07:16 PM
  5. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
