Thread: 1999 Audi A4 tdi fuel consumption
  1. 1999 Audi A4 tdi fuel consumption
    Sep 2009
    Swindon, England
    My first post. I've just bought a 1999 Audi A4 1.9 tdi with 125k on the clock. I only do motorway miles and I'm a bit surprised that I'm only getting around 42 mpg on my route (370 miles, 40ltr of fuel). I don't thrash it (75mph). Air filter clean, tyre pressures good, but not done any further investigation as I can't get hold of a Haynes Manual at the moment.
    Am I being too optimistic expecting more mpg for this type of driving?
    Many thanks in advance to any help I receive. (I foolishly put this on the general chat forum last night - whoops!)
    Brian
  2. Re: 1999 Audi A4 tdi fuel consumption
    Southern County Softy
    20 Post(s)
    Is that true MPG or what the DIS is telling you.
    The DIS is not accurate, try to get a true MPG, fill up to fill up.
    A4 2.5 tdi QS (mapped)
  3. Re: 1999 Audi A4 tdi fuel consumption
    Sep 2009
    Swindon, England
    This is true mpg - i don't have a DIS (or know what it is for that matter!)
    I topped up the tank, drove 370 miles, and topped it up again, using 40 ltr fuel. I do the same journey twice a week (glasgow to swindon) and i know i'm using about 40 ltrs each journey.
    I just think i should be using a bit less fuel. Any thoughts as to the next step to take?
  4. Re: 1999 Audi A4 tdi fuel consumption
    20 Post(s)
    OK, DIS= Driver Info system, the display between the clocks that shows avg, actual miles to empty, you might not have it.
    Try driving at the speed limit instead of over, that can increase MPG.
    You could have a failing AMM, (air flow meter that helps regulate fuelling)
    Maybe try a fuel additive, to clean up fuel lines and injectors.
  5. Re: 1999 Audi A4 tdi fuel consumption
    Aug 2007
    Hi Brian,
    You're probably best posting this in the A4 B5 topic for an answer:
    https://www.vwaudiforum.co.uk/forum/f...play.php?f=109
  1. New Audi A4 2.0TDIe
    By onemanparty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-01-2010, 01:28 AM
  2. A3 dashboard change & fuel efficiency
    By tlionhart in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-06-2009, 05:49 PM
  3. New audi s4 raises the benchmark for handling dynamics
    Last Post: 12-05-2009, 08:10 PM
  4. World Debut For The All New Audi A3 Cabriolet
  5. Replies: 0
    Last Post: 29-06-2006, 08:27 PM
