Thread: Location of Convenience Module
Results 1 to 8 of 8
  1. Location of Convenience Module
    Aug 2009
    Stornoway Isle of Lewis
    Hi guys. I've been having problems with the central locking A4 B5 1999 T plate 1.8T. Seems to be down to this convenience module but I cant find it. I have had the passenger seat out and had the carpet lifted right up with no sign. Took the boot apart and still no sign. Can anyone help?
  2. Re: Location of Convenience Module
    Chester-le-Street, United Kingdom
    i thought it was in the passenger footwell,someone will tell us better---
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Location of Convenience Module
    Jul 2008
    stoke on trent
    theres no such thing so your going to struggle finding it
    b6 + have central conveniance units (and b5.5 passats)
    all b5's have a central locking pump that operates c/l, alarm, interior lights, electric windows etc...
    its located in the boot on the right under the trim below rear light
    the only thing under passenger seat is a crash sensor
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
  4. Re: Location of Convenience Module
    Mar 2008
    Just Cumbria now.
    Quote Originally Posted by olds_kool View Post
    t
    and B5 passats also!!
    Nothing to see here, move along..
  5. Re: Location of Convenience Module
    Aug 2009
    Thanks for that. Pulled the pump out today and took cover of. Looked a bit black inside and smelled a bit burnt. Looks like that'll be the problem then
  6. Re: Location of Convenience Module
    Jul 2008
    stoke on trent
    if the circuit boards black im guessing that pump runs but doesnt operate locks?
    if so the graphite impeller will have shattered, they are repairable
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...STRK:MESELX:IT
    90 eunos roadster
  7. Re: Location of Convenience Module
    Aug 2009
    I'll need to look into that. About a year ago I had that problem an got the impeller changed. Was working fine till a few weeks ago. The odd time the car will unlock with the door lock and if you manually open all doors they will allways lock and you can hear the pump running fine. Had problems with the interior lights aswell. They were staying on all the time and have to leave them in the off positon.
  8. Re: Location of Convenience Module
    Jul 2008
    stoke on trent
    sounds like you need a new pump but try removing as much dust as possible as in theory it could cause a short somewhere so its worth a try cleaning first
    90 eunos roadster
  1. Convenience module programing
    By Sparky69 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-06-2009, 06:10 PM
  2. Convenience Module
    By Marc97 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-05-2008, 01:59 AM
  3. Replies: 7
    Last Post: 07-04-2008, 09:00 PM
  4. Replies: 0
    Last Post: 30-03-2008, 02:46 PM
  5. ABS control module 1998 VW Passat GLS 1.8L turbo
    By adrian537 in forum Chat - Completely Off Topic
    Last Post: 13-11-2007, 11:02 PM
