Thread: Warning Light... Help!
  1. Warning Light... Help!
    Mar 2008
    I have 2002 90bhp TDi Bora with 95k on the clock. On the way home tonight the Heater Plug light on the rev counter started to flash. Ive tried to look it up in the manual bt it's suitably vague. Can anyone tell me what this means and more importantly is it serious?
    Many thanks.
    Regards,
    Geoff
  2. Re: Warning Light... Help!
    Mar 2008
    OK, Checked through the forum and it seems it could be the brake lights. I've checked the car and the rear lights are out including the one on the back shelf. I'm going to try new bulbs now but if that doesn't work how difficult is the brake switch, mentioned in another post, to put in myself?
    Thanks,
    Geoff
  3. Re: Warning Light... Help!
    Jan 2008
    Southampton, Hampshire
    Piece of cake to fit and relatively cheap as well. When I did mine it cost about 6quid from a main dealer for the part.
    The switch is above the brake pedal in the footwell. I can't remember the exact procedure (ie whether I had to take trim off etc) as it was quite some time ago and my memory is rubbish but it is simply a case of removing the exisiting switch (screws + plug) and fitting the new one.
    Rob
    '01 Bora TDi130 Sport
  4. Re: Warning Light... Help!
    Mar 2008
    Cheers for that. All up and runing again.
    Geoff
  1. Question Fog lights install
    By deadly4u2nv in forum Golf MK5 - 2004 - 2009
    Last Post: 26-11-2014, 12:59 PM
  2. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  3. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  4. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  5. Which HID kit?
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2008, 07:36 PM
