Thread: How to strip and rebuild a rear caliper
  1. How to strip and rebuild a rear caliper
    Car is a late 97 2.8 quattro saloon (first of that shape) and fluid is loeaking from the drivers side rear caliper. I've traced it to the seal which is between the caliper body and handbrake mechanism (cable operated).
    I managed to source a full rebuild kit which contains every single rubber piece to rebuild the caliper but I have a couple of questions.
    Firstly, in order to get the piston out can I remove the caliper and wind it out using the winding tool I have or do I need to leave it on the car and pump it out using the brake pedal?
    Secondly, does anyone have an exploded diagram of the caliper?
    Thirdly, Is there anything I need to watch for?
    And finally, are there any other special tools I need? From looking at it I don't think so but I'd like to be sure.
    Niall76
  2. Re: How to strip and rebuild a rear caliper
    May 2009
    rhodesia, nottinghamshire
    Hi mate, fairly easy to do, you can unwind it after you have removed it, and you dont need any special tools, just apply a little rubber grease on seals when refitting new one's. have fun!!
  3. Re: How to strip and rebuild a rear caliper
    Thanks Steve. Being able to remove the caliper while it's off the car will make the job a lot easier.
  4. Re: How to strip and rebuild a rear caliper
    Inspect the seal surfaces of the caliper and the banjo very,very carefully if necessary reface and polish them and refit with copper washers. These washers should be anealed and no more than 1mm thick. Regards Peter
  1. Gearbox rebuild
    By audimad in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-04-2008, 03:00 PM
  2. Making and appointment
    By Crasher in forum Chat - Anything with wheels
    Last Post: 06-04-2008, 07:37 PM
  3. golf, rebuild, repsray and everything new
    By cuprajake in forum Golf MK4 - 1999 - 2004
    Last Post: 15-02-2008, 09:41 AM
  4. A4 B5 1.8 ADR Won't start after rebuild
    By Bugandbus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-02-2008, 06:24 PM
  5. A4 Avant rear 12v socket fuse
    By Tanuki in forum Audi A4 - Archive Topics
    Last Post: 10-01-2007, 12:06 AM
