Thread: Engine Management Light (coil symbol)
Results 1 to 10 of 15
  1. Engine Management Light (coil symbol)
    Aug 2009
    Liverpool UK
    Hi
    Me again with my 06 2.0 TDI Sport.
    I've just driven along the motorway and the 'coil' symbol started flashing on the dash. A message then came up saying 'Engine fault - garage'.
    I then seemed to lose turbo, but not all power as I could still accelerate, just not as quickly as, I've said, it appeared the turbo wasn't kicking in.
    I got home, turned the engine off, and immediately restarted it. The light had gone off and I took it for a quick spin and the car seems to be functioning normally, turbo and all.
    Should I be concerned?
  2. Re: Engine Management Light (coil symbol)
    Norfolk
    It dropped into limp mode. If you get a code read done it may tell you why. You could wait for it to happen again or get it checked now. Personally I would check it now, just incase.
  3. Re: Engine Management Light (coil symbol)
    Aug 2009
    Liverpool UK
    Cheers for that.
    What is limp mode, and what normally is the cause? Does this mean VW produce a range of viagra?
  4. Re: Engine Management Light (coil symbol)
    Aug 2008
    worcester
    Quote Originally Posted by rob1990 View Post
    Cheers for that.
    08Sport Est, 170DSG, Deep Black, BiXenon, ipod dock, SatNav&cam, f/r park sensors, winter pack, comfort pack, heated seats, f/f premium btooth, cruise control, rearblinds, mfsw&paddles
  5. Re: Engine Management Light (coil symbol)
    Norfolk
    When the engine ecu detects a signal out of spec it stops the turbo boosting, incase you damage the engine. This is called "limp home mode". It is usually due to a turbo fault being detected. I would get a code read done.
  6. Re: Engine Management Light (coil symbol)
    Aug 2007
    Ware, Herts
  7. Re: Engine Management Light (coil symbol)
    Aug 2009
    Liverpool UK
    Again, thanks.
    Can I do this at home? I've seen numerous cable/software packages on ebay, and it's just that my nearest VW dealer is several light-years away from me.
    And which type of cable/software would I need? Would this one be ok:
    http://cgi.ebay.co.uk/Auto-VAG-COM-D...d=p3911.c0.m14
    Sorry about the numerous questions, but all help is much appreciated!
  8. Re: Engine Management Light (coil symbol)
    -just replying so that I see any response to the last question.
    I would find it hard to justify the cost of the standard VAG-COM package, which from memory is about £200. However, if the Chinese version is any good for routine fault code checking/clearing, £20 would be a no-brainer.
    Mike
  9. Re: Engine Management Light (coil symbol)
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by mikecb1 View Post
    Mike - if you click on 'Thread tools' at the top of the page you can subscribe to the thread.
    2006 (Dec.) B6 2.0TDi 140 Confort | Moka anthracite nacré | CControl | Highline MFD | Chrome Grill | Meta Targa rear parking sensors | Debadged
    1996 Laguna 2.2D
    1977 MGB roadster
  10. Re: Engine Management Light (coil symbol)
    Norfolk
    Rob..You can't use the cheap cables on a B6 passat. The only thing that works vag-com is the can-bus dongle from Ross-tech plus their software. Costs about £260 from Gendan or Ilexa. You can get a handheld scanner for about £90. Search on here for recent thread.
  1. Engine Management light...MAF problem?
    By KevBrowne in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-06-2009, 02:56 PM
  2. A4 engine management light .help
    By piggyA4 in forum Audi A4 - Archive Topics
    Last Post: 28-11-2007, 12:25 AM
  3. Engine Management Light
    By Chris Russell in forum Audi A3 - Archive Topics
    Last Post: 07-10-2007, 02:59 AM
  4. 2002 02 Audi A4 1.8T Sport Engine Management Light
    By KerryLou123 in forum Archive posts
    Last Post: 27-06-2007, 10:49 AM
  5. A4 engine management light
    By karl j moran in forum Chat - Completely Off Topic
    Last Post: 09-10-2006, 03:52 PM
