Thread: fault codes
  1. fault codes
    engine management light has been on for about a week ,well since i got it back from audi/vw garage to replace a cracked hose.put diagnostics on it before and got-
    3 engine faults-
    17700-map controlled engine cooling thermostst-open circuit
    17544-shareware version.to decode all DTCs p1136-001-please register/activate
    17947-shareware version. to decode all DTCs p1539-004-please register/activate-intermittent readiness 0000 0001
    and ABS Brakes-
    sensor for steering angle (g85)supply voltage terminal 30 35-10---intermittent.
    i think the shareware code 17544 comes up as long term fuel trim,idling, bank 1 system too lean.which ive had before and changed the AMM and the problem went!!
    can anyone shed any light on these??/
    much appreciated.
  2. Re: fault codes
    Jan 2009
    towcester northants
    map controlled thermostat is the thermostat housing complete
    replace part as known to fault
    steering angle sensor battery was flat or disconnected
    thermostat may cause the other faults
  3. Re: fault codes
    Audi replaced a split pipe in engine,so this might explain you saying battery may have been disconected(needed to take head off to get to it).will have to get them to look at thermostat when they replace the dipstick they broke.
    cheers
  4. Re: fault codes
    Nov 2008
    N/A
    They should know that that code would pop up when the battery was changed and they should have cleared it.
  1. alarm fault codes
    By A6TYY in forum VCDS - Help Requests
    Last Post: 17-08-2009, 08:01 PM
  2. Healp needed VAG com
    By Snooze1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-06-2009, 07:47 AM
  3. Replies: 6
    Last Post: 13-05-2009, 05:20 PM
  4. Check my scan
    By kite in forum VCDS - General Questions
    Last Post: 11-05-2009, 08:03 PM
  5. Why do these OBDII / DTC Fault codes keep coming back ?
    By headache56 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-11-2007, 07:01 PM
