Thread: Catalyst system fault - o2 sensor?
Results 1 to 10 of 12
  1. Catalyst system fault - o2 sensor?
    May 2007
    South East London (West Thamesmead)
    Hi I have scaned and found two fault codes - i have cleared them but they return within a day or so, first i only had bank 1 then a couple of weeks later bank 2 also.
    (its a n A4 2.4 V6 year 2000)
    16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
    16814/P0430/001072 - Catalyst System; Bank 2: Efficiency Below Threshold
    has any got an idea if this could still be related to the sensors ? CAT's? - is it not strange that both sensors would fail at the same time? or does this indicate that there is another problem somewhere else? as always any help or suggestions much appriciated!
    I have done a readiness test and the result is below...could it "just be the o2 sensor"?
    d
  2. Re: Catalyst system fault - o2 sensor?
    May 2007
    it passed MOT emmison test with no problems....?
  3. Re: Catalyst system fault - o2 sensor?
    Nov 2008
    folkestone.kent
    you need to check the rear lambdas are working
  4. Re: Catalyst system fault - o2 sensor?
    May 2007
    the lambda - is the O2 sensor right? - can it be checked vith vagcom? or it there a simple way to test it??
  5. Re: Catalyst system fault - o2 sensor?
    Nov 2008
    folkestone.kent
    yes vag.com it i carnt remember the numbers but if you have a label file it will tell you in there ,the rear should be as close to 0.00 as possible it will never be that good but should be somewhere close what was the fault code ?
  6. Re: Catalyst system fault - o2 sensor?
    May 2007
    the fault codes where
    when i ran a readiness test on the engine it came up with "FAILED" under certain elements (see screenshot in begining of post)
  7. Re: Catalyst system fault - o2 sensor?
    May 2007
    might be a stupid question but what do you mean with "label file"? - should i have one? /where do i get one?
  8. Re: Catalyst system fault - o2 sensor?
    Nov 2008
    folkestone.kent
    label file is at the top of the screen when you have gone into engine,measuring blocks...it will be on top of the screen and those codes mean the cat aint working properly so i would check those rear lambdas first
  9. Re: Catalyst system fault - o2 sensor?
    135 Post(s)
    2038 Post(s)
    That says Air Mass Meter to me or a post AMM air leak.
  10. Re: Catalyst system fault - o2 sensor?
    May 2007
    dont think is the MAF as it is fairly new (12 month)...what is the post AMM?
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. Vag com 17552 maf sensor fault
    By peterdelphi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2009, 08:27 PM
  3. Replies: 0
    Last Post: 14-11-2007, 10:16 PM
  4. How does the Quattro system work?
    By webchem in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 01-07-2007, 04:44 PM
  5. The new Audi A6 Avant
