Thread: window regulator replacement
  1. window regulator replacement
    Sep 2009
    wales
    Good evening.This is my first post on you forum so thank you before i start.After borrowing my wifes polo estate 1.9 tdi, 2000reg one day last week i managed to wreck the drivers side electric window regulator.Have removed the outer door card and the plastic cover. found a very sick looking piece of cable .My local garage has suggested that the regulator obtained from vw parts will be in excess of £170. plus his labour.Once i picked myself up off the floor got the courage to post and ask the forum.
    1.Could anyone suggest an alternative supplier.The regulator i belive is twelve pin.and is this one also common to the seat variant /estate
    2.Is the removal and replacement a task i could undertake myself.
    3.Without sounding to silly, if the glass has to be removed do you remove via the top of the door? and then remove the old regulatio via the cut out in the inner door pannel?
    I would be gratefull for any help or if you can direct me to where i can get som information.sorry about the spelling could not find the spellcheck.
  2. Re: window regulator replacement
    Jan 2009
    towcester northants
    hes having you on
    last full reg i done was £65
    check with VW to see if they do a repair kit
    a bit fiddly to do if its your first
  3. Re: window regulator replacement
    Sep 2009
    strathaven scotland
    Try Eurocarparts who have a website and ask for an after market window regulator
  4. Re: window regulator replacement
    Sep 2009
    wales
    Thank you for your replys .Nice to know that there is assistance out there.Will let you know how i get on.
  1. Polo 6N2 electric window fault
    By zoro in forum Polo - Derby - Lupo - Fox
    Last Post: 18-11-2008, 10:11 AM
  2. Sharan nsf electric window problem
    By colinwdick in forum Touran - Sharan - Caravelle
    Last Post: 15-07-2008, 11:51 PM
  3. GOLF N REG Electic window problems
    By Mikege in forum Golf MK4 - 1999 - 2004
    Last Post: 22-05-2008, 08:11 PM
  4. Noisy/clicking window
    By dcorcouk in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-04-2008, 06:08 PM
  5. Help! Clicking window problem.
    Last Post: 11-03-2008, 09:58 PM
