Thread: Injector loom recall?
  1. Injector loom recall?
    Sep 2009
    Tamworth
    Does anyone know if there is a common fault or a recall on the short loom under the rocker cover on an A4 1.9tdi?,im supsecting mine is faulty,
    there is a misfire in 4th/5th gear under load at motorway speeds,
  2. Re: Injector loom recall?
    131 Post(s)
    1974 Post(s)
    No recall but a very common problem and the loom is usually kept in stock at all dealers and TPS depots. Start by having a code read carried out.
  3. Re: Injector loom recall?
    Sep 2009
    Tamworth
    hi,do you knowif itseasy to replace??
  4. Re: Injector loom recall?
    131 Post(s)
    1974 Post(s)
    Quite easy, just remove the cam cover - I have changed hundreds. Transverse engine installations are a pain due to the EGR valve but on a longitudinal engine installation like the A4 the most awkward part is getting the old harness out of the head against the bulkhead without it shattering and filling the engine with bits of broken plastic. I always use a hot air blower to warm a new one so it is more flexible feeding it into the head hole.
  1. US Passat Recall?
    By davey_g23 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2008, 08:07 PM
  2. how do i read e mails i've sent
    By STEWY L in forum Chat - Completely Off Topic
    Last Post: 15-03-2008, 07:41 PM
  3. Audi Missed Recall On A6 Leads To Fire
    By loyal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-06-2007, 06:18 PM
  4. Seat Belt Recall Problems / Recall?
    By ChillOut in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-04-2007, 02:48 PM
  5. Recall Codes Help
    By pintpotter in forum Archive posts
    Last Post: 06-02-2007, 04:28 PM
