Thread: Mk2 diesel golf glow plugs light
Results 1 to 10 of 34
  1. Re: Mk2 diesel golf glow plugs light
    Hi again, Converted? the registration cert, says Glf diesel 1898cc engine no. 1y6116718. How do i test the temp sensor and am i right that its the right hand side (Nearside) of head? i have a multimeter thingy.
    Thanks again matey
  2. Re: Mk2 diesel golf glow plugs light
    135 Post(s)
    2042 Post(s)
    PM me the cars chassis number.
  3. Re: Mk2 diesel golf glow plugs light
    Men, Ive just fitted a new coolant temp sensor and would you believe it? The glow plug light still dosent come on!!!!, She started after a long time turning over but its quite warm today, what would be next to check change?
    Thanks j
  4. Re: Mk2 diesel golf glow plugs light
    135 Post(s)
    2042 Post(s)
    Are you going to give me the chassis number?
  5. Re: Mk2 diesel golf glow plugs light
    Mate i thought i had on email, but here you go WVWZZZ1HZVW131871.
    tHANKS J
  6. Re: Mk2 diesel golf glow plugs light
    135 Post(s)
    2042 Post(s)
    Two things, it is a 97 Golf 3 1.9D estate, not a Golf 2. Secondly, get it read for fault codes and this will probably tell you what is wrong. On the 1Y engine this is done in Diesel pump electronics control unit (address word 41) not Engine 01 as with TDI engines.
  7. Re: Mk2 diesel golf glow plugs light
    Ta, do you know whether this is a garage only job or are some mobile mechanics geared up for this? As you can imagine getting it garage is a prob.
    j
  1. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  2. Glow plug light golf SDI 03
    By Gary C in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2008, 04:48 PM
  3. Replies: 4
    Last Post: 04-04-2008, 07:34 AM
  4. Replies: 0
    Last Post: 08-02-2008, 10:45 AM
  5. 24 MILLIONTH GOLF ROLLS OFF LINE - EXPANDED UK GOLF RANGE
    Last Post: 19-11-2005, 05:57 PM
