Thread: Golf CL Mark II 1.3. Three problems.
  1. Golf CL Mark II 1.3. Three problems.
    Bullet 350 Guest
    Hi there,
    I have three problems with my mark II at the moment. I'd appreciate any help. If these questions have been asked before I apologise but I need explanations in layman's terms - I'm not a mechanic, even the Haynes manual bewilders me.
    • The car is losing power sometimes, I can feel it starting through the accelerator. It'll then struggle on hills and cut out when I come to lights if I don't keep the revs up. This usually only happens on longer journeys and because it happens generally in the morning or at night I think it's related to cold air temperature.
    • The heater doesnt work anymore. It blows fine but apart from a couple of seconds when first turned on it is cold. Is this the over zealous bypass valve I've seen on other posts?
    • There's a rattle from the front of the car when it's idling, going slow and especially going over bumps. It's more of a clatter really. I've tugged and pushed everything under the hood but there doesn't seem to be anything loose.
    Thanks.
  2. Re: Golf CL Mark II 1.3. Three problems.
    ipswich, england
    i dont know if the CL is he same as the standard golf but i also have a mk2 1.3 and had the same problems all before my head gasket went, so its a possability it could be that, is it using alot of water? is there alot of white steam from the exhaust?
  3. Re: Golf CL Mark II 1.3. Three problems.
    Bullet 350 Guest
    I did notice some whitish smoke or steam from the exhaust the last time it happened yes. It isn't using up much water at all though.
    The gasket was changed along with the thermostat last year when a mechanic misdiagnosed a simple problem when the car was overheating, (turned out I just needed to replace the coolant expansion tank cap).
  4. Re: Golf CL Mark II 1.3. Three problems.
    Bullet 350 Guest
    Anyone else got any ideas?
  5. Re: Golf CL Mark II 1.3. Three problems.
    Jun 2008
    hi there is one or two factors for ur problem. i also have the 1.3 cl with the running problem. what many people say is that it is infact the carb. r u running the pierburg 2e3 carb? if so it is recommended tht you upgrade to the weber 32/34 dmtl or dmtr although very hard to find for the 1.3. your other problem for the heater maybe that the thermostat may need replacing or there maybe an air block. so i would suggest checking that.
    hope this helps
  6. Re: Golf CL Mark II 1.3. Three problems.
    Nov 2009
    Ilford
    hi mate i own an 1.3 cl 1985 mk2 golf , had all the issue you have
    heating issue - was the heater matix valve (replaced the lot in 1 go) - works fine after
    Stalling issue - adjust the idle , clean the carb with sum carb cleaner , change the fuel filter , adjust the ignition timing advance it a tad (replace rotar arm and cap and leads if there old and worn), clean/replace air filter (removed and used old tights runs alot better!)
    Rattle noise - this happen about 1month ago , (got told it was brake pads, wrong!) it was infact the driveshaft nut that had come lose and the shaft was ratlling around in the hub! (sort this out as if it rounds off the theeth off then it a new shaft time!)
  1. Problems with Golf gti turbo (Mark 4)
    By misseyy in forum Golf MK4 - 1999 - 2004
    Last Post: 03-01-2008, 09:34 AM
  2. Golf Mark 3 TD - Iginition Switch problems - help please
    By Bellavilla1@ntlworld.com in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 28-02-2007, 01:51 PM
  3. Mark 3 Golf problems
    By victorwhiskey in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 26-09-2006, 06:28 PM
  4. MARK 2 GOLF SLOW IDLE RUNNING PROBLEMS
    By LIZSTOBB in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-09-2006, 10:21 PM
  5. Golf Mark 3 Lowering Problems
    By Alun in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-07-2006, 06:42 PM
