Thread: Golf MK3 TDI 1996 power loss over 60mph
Results 1 to 9 of 9
  1. Golf MK3 TDI 1996 power loss over 60mph
    Feb 2009
    hello, i think i may have a problem with my 1996 golf tdi, when i reach 60mph i seem to get some power loss and can be a problem getting up motorway hills im guessing its a problem with the turbo can anyone help regarding this could it be a pipe or something, power seems ok when around town lower speeds.
    any help would be great
  2. Re: Golf MK3 TDI 1996 power loss over 60mph
    Dec 2008
    Your timing is impeccable. I have recently had similar problems.
    Read this:
    http://forums.tdiclub.com/showthread.php?t=75959
    It's unlikely to be a turbo (being broken) problem as apparently they are pretty solid units, but you should be able to suss it out following the above thread.
  3. Re: Golf MK3 TDI 1996 power loss over 60mph
    Feb 2009
    thanks for that, ill have a look but i dont know if my car has an ecu?
  4. Re: Golf MK3 TDI 1996 power loss over 60mph
    Dec 2008
    What's your engine code?
    I'm pretty confident your car has an ecu.
    If you take out the ashtray, slide the panel to the left of the ashtray across to the right to reveal the OBD diagnostic port (way of communicating with the ecu) This will confirm it.
  5. Re: Golf MK3 TDI 1996 power loss over 60mph
    Sep 2009
    Guildford UK
    Hi, I had EXACTLY this problem with mine. Prooved to be a little boost control valve situated near the air mass meter. The valve wasn't allowing the waste gate to open so turbo was over boosting, engine ECU sees too much boost so backs off the throttle to protect itself. The control valve is mounted on the inner wing by 2 rubber pegs, has 2 or 3 braided pipes rubber pipes and a wiring pulg attached ot it. Try to borrow 1 from a donor car and test it. ps, the rubber pegs usually snap so be careful.
  6. Re: Golf MK3 TDI 1996 power loss over 60mph
    Feb 2009
    can i fiddle with this boost control to make ot faster? where is it?
  7. Re: Golf MK3 TDI 1996 power loss over 60mph
    Dec 2008
    In short, no.
    You could probably increase the boost, but then you have to match it with increased fueling.
    Better to just buy a tuning box off ebay if that's what you want to do.
  8. Re: Golf MK3 TDI 1996 power loss over 60mph
    Feb 2009
    Quote Originally Posted by jet View Post
    In short, no.
    i thought they messed stuff up!
  9. Re: Golf MK3 TDI 1996 power loss over 60mph
    Dec 2008
    If you pick carefully you should be ok. Don't just go for the cheapest, do some forum research and find out the type people have used before that worked
  1. 96 Golf MK3 - loss of power and no start
    By RMANN in forum Golf MK3 - 1993 - 1999
    Last Post: 26-11-2007, 07:37 AM
  2. golf tdi power loss at 70mph
    By justin@justinwa in forum Archive posts
    Last Post: 12-11-2007, 08:48 PM
  3. How does the Quattro system work?
  4. Mk3 Golf Tdi (1996) acceleration problem
    By Octavius in forum Golf MK3 - 1993 - 1999
    Last Post: 28-03-2007, 05:50 PM
  5. Whistling Turbo
    By alecmac in forum Vento - 1994 - 1998
    Last Post: 15-03-2007, 12:31 AM
