Thread: Oil Level Warning Light
  1. Oil Level Warning Light
    Feb 2007
    North Yorkshire
    Experts
    Today the amber oil level warning light came on on my car and after topping the oil up (approx 0.75 litre required) to the MAX line on the dipstick, the amber warning light still remains on. I've check and re-checked the oil level and it is now definitely on the MAX line.
    I called the main dealer and was advised that the problem could be down to the bonnet catch switch not recognizing that the bonnet has been open and closed, thus signaling the oil level has been checked. Alternatively they said it could be a faulty oil level sensor. Either way it would need "looking at"
    Has has anyone else ever experienced this problem..?
    Could it be the bonnet sensor..? (I was surprised with this theory..!)
    Is the more likely cause a dodgy level sensor..?
    Any non-dealer solutions/checks to this problem..?
    Hope this makes sense..!!
    Mark
    PS - This car seems to use varying amounts of oil and regularly catches me out even though I check the oil frequently - Most annoying..!!!
    2010 Audi A4 Avant 2.0 TDI 143PS S-Line Special Edition | Misano Red | B&O | DAB | AMI
  2. Re: Oil Level Warning Light
    Norfolk
    Both reasons you were given are possible. I would try disconnecting the battery for 5 mins. This sometimes resets some aspects of the ecu.
  3. Re: Oil Level Warning Light
    Apr 2007
    France
    12 Post(s)
    Seems a bit far-fetched to think that opening and closing the bonnet would make the ecu think the oil has been 'checked'. Checking doesn't change the oil level, so I can't see why the light wouldn't stay on in those circumstances.
    1996 Laguna 2.2D
    1977 MGB roadster
  4. Re: Oil Level Warning Light
    Sep 2009
    England
    Bonnet catch switch failure is a very common cause for this fault! - The dash cluster wants to see that the bonnet has been opened so you can top up the oil - If it hasn't seen this signal then it doesn't recheck the oil level via the sensor!
  5. Re: Oil Level Warning Light
    Apr 2007
    France
    12 Post(s)
    Quote Originally Posted by Pit Dweller View Post
    That sounds like a recipe for disaster!
    1996 Laguna 2.2D
    1977 MGB roadster
  1. Please Help Oil level light
    By Natashamary in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-04-2009, 12:59 PM
  2. 1.9 TDI PD 150 Oils
    By mikebeardmore in forum Golf MK4 - 1999 - 2004
    Last Post: 19-04-2009, 11:36 PM
  3. 1.8T oil pressure on motorways
    By pippip in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-04-2009, 01:03 PM
  4. Oil colour
    By d@ve in forum Golf MK4 - 1999 - 2004
    Last Post: 27-10-2007, 10:28 PM
  5. A3 1.9TDi PD130 servicing intervals
    By michaelab in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2007, 04:12 PM
