Thread: How to clean oil from exhaust?
  1. How to clean oil from exhaust?
    Aug 2009
    Northern Ireland
    Hi all,
    Just recently got the turbo changed on 2002 B5 passat.
    the car is going well again, but the problem i have is that when the car has been running sometime I get quite a bit of smoke from the exhaust.
    I was told that there may be some smoke as a lot of oil was dumped into the exhaust when the turbo blew but that it would burn off. (the oil was actually coming out of the exhaust at one stage)
    Was wondering if there is any quicker methods of removing / cleaning the oil from the exhaust. This car is used for the school runs and not sure how the other half will feel about driving the car until it "burns off"
    TIA
  2. Re: How to clean oil from exhaust?
    Pembrokeshire
    22 Post(s)
    the problem is that the oil will sit in the lower part of the exhaust i.e in the silencer boxes. short runs dont get the exhaust hot enough , but a long run would, but the smoke this would create would endanger other road users and attract the attention of the police. the best solution is to remove the exhaust and leave it standing up to allow the oil to drain. this will get rid of the bulk, but will still leave residue in there. the easiest option is a new exhaust, but after forking out for a turbo, i dont think you would be too happy about that suggestion.
  3. Re: How to clean oil from exhaust?
    had exactly the same problem, puddles of oil underneath the pipe, oil splats on the rear of the car, just drive, drive and drive, think it took bout 600 miles til mine was totally clear,
  4. Re: How to clean oil from exhaust?
    Mar 2007
    simply drive the car luv. Will disapear very quickly when your doing 70mph in the car on the motorway :P
  1. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  2. Basic Oil advice from Opie Oils
    By oilman in forum Chat - Completely Off Topic
    Last Post: 09-09-2009, 03:11 PM
  3. Oil and thick white smoke from exhaust
    By mattbrown98 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-04-2008, 03:10 PM
