Thread: Drl
Results 1 to 10 of 10
  1. Drl
    Nov 2008
    I have an A6 Avant 1.9TDi CVT 05 Plate. The last of the old style body. I should like to activate DRL on this vehicle as other drivers frequently cannot see me!! I am also an ex Volvo driver!!! The car must have been available in other countries where DRL are manatory?
    Can the DRL option be activated by my main dealer? I note that in the A5 forum it appears to be possible to access the ECU and change bytes and bits.
  2. Re: Drl
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by RJHAW View Post
    I believe this can only be coded/activated on the newer A6 chassis (4F) in central electrics, not available in your A6 (if it is a 4B Chassis) perhaps a wiring mod is available?
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Drl
    I think i saw on here somewhere that if you use vagcom to change the country code in the instrument control module to canada then your side lights come on with the ignition.
    If i remember right i think that changes the way the date and time displays on your clock too though.
    Below is the link to the rosstech page.
    I'll try changing it myself and see if the sidelights come on automatically.
    http://wiki.ross-tech.com/index.php/...2000%29#Coding
    2016 A6 2.0 TDI S-Line
    1969 Triumph Spitfire (In pieces )
  4. Re: Drl
    So much for that plan
    i just tried recoding that at lunch time and it didnt work.
    It just turned on one of those irrating US type door open warnings
    and changed the door open display from showing the right thand door open to show the left hand one open instead but no lights
  5. Re: Drl
    Nov 2008
    Many thanks for the information. I can confirm that it is a 4B chassis. Surely this car was also m ade for the Swedish or other market where DRL are mandatory!
    Thanks aslo for trying the Canadian mode, I hope you've now got it back to normal with the right door recognised!
    I hope that someone may have a simple mod - please keep looking chaps!!
    Regards
    Robert
  6. Re: Drl
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by Redzer View Post
    I Know on the Passat the side lights (DRL's) don't come on until the handbrake is released!! did you take it a run?
    Andy
  7. Re: Drl
    No i didnt...i just started the car up....i'll try it again at the weekend and try some of the other country codes too.
    even if the canadian country code worked I think i would prefer to manually turn on the sidelights rather than listen to the bong bong bong bong bong whenever you opened the door with the key in the ignition.
  8. Re: Drl
    Ayrshire, Scotland
    18 Post(s)
    I agree if it actaually works it is not worth it,
    It shouldn't bong as the key is in the ignition unless you physicaly switch the side lights on and open the door (passanger door!!), as the driver door thinking it is the passanger door and vise versa would lead to many problems so its probably not worth it. . It would be very confusing if the doors are the wrong way around and would lead to unussual scenarios!!
    Andy
    EDIT:
    It will bong!!
    just read your last post about the annoying US type door open Chime, now i get it!!
    Andy
    Last edited by bagpipingandy; 10-09-2009 at 12:37 PM. Reason: not reading previous post correctly!! :)
  9. Re: Drl
    Just as an FYI, i tried all the different country codes and none of them made any difference to the lights, sorry.
  10. Re: Drl
    Mar 2009
    Chester
    Why not just turn your sidelights on when you get in to the car?
    2003 A4 Avant 1.9 TDI SE 130bhp (Current)
    1999 A3 1.6 S (Gone)
    1996 Polo 1.9 D (Gone)
    Xbox Live ID: Alistair1234
  1. B7 DRL Upgrade Bulbs (White)
    By Neve187 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-06-2013, 10:08 PM
  2. DRL lights on a3
    By quinny_88_171 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-10-2010, 06:38 PM
  3. Cabling of LED DRL as fog lights
    By rtp in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-09-2009, 12:32 PM
  4. a4 b7 devil eye drl
    By del300_0 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-08-2009, 08:35 AM
  5. Antihijack, DRL, Alarm sound, Range
    By Imran in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2008, 04:25 PM
