Thread: Airbag Warning Light on permanent
  1. Airbag Warning Light on permanent
    PeteOwen Guest
    On moving drivers seat forward, got a permanent airbag warning light, first time it reset, then moved seat again came on and now will not reset.
    Faults code is 01217 - Side Airbag Igniter drivers side (N199)
    possibly resistance too high or upper limit exceeded? Causes are possibly faulty igniter or wiring.
    As I have very limited knowledge of this issue, any help appreciated.
    I have located the wiring plug connector under drivers seat, all looks ok, took it apart cleaned it,but how to check if it's OK, and where the igniter i s located I haven't a clue.
    Any help/advise much apprecited
    A3 Sport TDi 2.0 2004 3 door
  2. Re: Airbag Warning Light on permanent
    Remove the connector and solder the wires together.
  3. Re: Airbag Warning Light on permanent
    PeteOwen Guest
    Quote Originally Posted by kenney View Post
    Thanks, I'll try that.
  1. Please Help Airbag warning light
    By fubar84 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 24-01-2011, 09:39 PM
  2. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  3. Foglights Retrofit - VW Jetta / Golf
    By RickT in forum Volkswagen
    Last Post: 27-06-2009, 06:06 PM
  4. Question should my car have brake pads wear indicator?
    By lucianus in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2009, 12:19 PM
  5. Which HID kit?
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-04-2008, 07:36 PM
