Thread: 2.5 TDI engine rattling noise then just cut out - not starting now
  1. Exclamation 2.5 TDI engine rattling noise then just cut out - not starting now
    Jun 2008
    Hello people, After owning a 2.5tdi caravaelle auto for a year, I decided to buy another one for my growing taxi fleet.
    So I bought a 2002 lwb caravelle manual, I noticed a rattling noise from the gearbox area which went away once the clutch pedal was pressed - I thought it would be the clutch bearing or flywheel, there was also a slight squeak from the left side of the engine which I thought was the alternator belt or something simple.
    I decided to buy the vehicle thinkin I would need to replace the clutch and possibly a belt, I drove it home 45 miles along the motorway achieving 90mph without too much stress, no smoke problems.
    The following day I went to start it and it sounded like a box of spanners, pressing the clutch did not help, I drove it a few hundred yards it felt low on power, I parked it up turned of the engine did the oil check etc, nothing obvious was loose or hanging off, I started it again - after 10 seconds it stopped it self ! Now the engine seems to turn over but no start.
    ANY HELP / ADVICE IS GREATLY APPRECIATED.
  2. Re: 2.5 TDI engine rattling noise then just cut out - not starting now
    Feb 2009
    Auztralia Mate
    i'd be looking in the timing belt area?
    N
  3. Unhappy Re: 2.5 TDI engine rattling noise then just cut out - not starting now
    Aug 2009
    perth wa
    same happened to mine.. it was the timing belt snapped!
    i have the same noise from the gearbox/clutch. some say its a gearbox bearing or clutch release(throw out) bearing.. can any one advise??
  4. Re: 2.5 TDI engine rattling noise then just cut out - not starting now
    Mind had the same noise. Dropped it off at the garage this morning and just had a call back and been told it's the gearbox, clutch and DMF!!!
    It was originally booked in due to suspect DMF. I trust the garage as it's a friend who has a vw specialist garage and won't charge any extra labour to fit gearbox.....now to source one!
  1. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  2. Audi covers new ground with 2010 q7 suv
  3. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  4. A6 2.5 TDI SE ENgine Management light
    By Red_Ade in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-04-2008, 11:23 PM
  5. Engine Noise passat tdi 130 auto
    By vw-passat-man in forum Archive posts
    Last Post: 16-09-2007, 05:16 PM
