Thread: vw 1.8 turbo 2001
  1. vw 1.8 turbo 2001
    Jan 2008
    hi all,
    our passat 1.8 turbo engine light has just came on AGAIN!!!. 1 month after coming from local v.w garage. this time rough idle aas well/ misfire. may be ignition coil packs . looking for some helpfull advice. last time in garage , lambda probe sensor changed. anyone help would be much appreciated.
    was there a recall for the coilpacks. been looking through internet for same problem.
    thanks
  2. Re: vw 1.8 turbo 2001
    133 Post(s)
    1987 Post(s)
    The only advice I can give you is to have a fault code read done, get a print out of the code (hopefully either a VAG specific or P code), have the code cleared and post the result so we can see what is stored.
  3. Re: vw 1.8 turbo 2001
    Jan 2008
    thanks crasher, in garage for tomorrow morning. will keep you posted on outcome
  4. Re: vw 1.8 turbo 2001
    Jan 2008
    yes it was ignition coil, dunno what one but now im £94 lighter...ouch!
    on another note.... can you change the coils without resetting the fault codes afterwards. or must they be reset for the car to run properly?
    thanks crasher once again
  5. Re: vw 1.8 turbo 2001
    133 Post(s)
    1987 Post(s)
    £94 for one coil pack, code read and a little labour is quite fair, I can’t see the ouch there.
  6. Re: vw 1.8 turbo 2001
    Jan 2008
    yes crasher part was £25. rest was test and reset. its just my dry sense of humour.
    i will probably buy the other 3 though.
  7. Re: vw 1.8 turbo 2001
    133 Post(s)
    1987 Post(s)
    Good idea, when one fails the others are normally on the way.
  1. VW Passat Tdi Sport 130 2002 - Loss of Power - Turbo not kicking in
    By iworld in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2013, 07:34 PM
  2. VW Golf GT TDI 150BHP - Turbo and Fan problems
    By Ade and Emma in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2008, 02:17 PM
  3. VW 1.6D - Turbo?
    By BugsyMalone666 in forum Chat - Anything with wheels
    Last Post: 04-04-2008, 10:08 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. Apparently I need a new turbo!
    By Matt B in forum Chat - Anything with wheels
    Last Post: 29-07-2007, 03:50 PM
