Thread: Retrofit A4 Front Armrest
Results 1 to 10 of 11
  1. Retrofit A4 Front Armrest
    Jul 2007
    I know this is a long shot but here goes anyway.
    Bought a secondhand front armrest for A4 saloon 2006 as it didn`t have one.I need to cut out the front console for fitting. My understanding is that when you buy an original retro kit it comes with a template to enable you to cut the console in the right place.
    Been searching the internet for advice someone informs that once the cosole has been removed that the underside is already marked ?? anybody know if this is the case
    Here goes has anyone got the template, or has anyone every fitted armrest in the past who had to cut the console??
    Any advice greatly appreciated
    TA
  2. Re: Retrofit A4 Front Armrest
    Dec 2007
    Quote Originally Posted by clio222 View Post
    TA
    it is marked on the under side but to take it out is a pain in the a$$ u get a template in the retro kit iv done a few and just drill a small hole and use a dremel or small hacksaw blade doesnt have to be perfect as its covered over i got a template from audi parts department he was good enough to photocopy 1 they had in stock im sure theres a few knocking around the net tho
  3. Thumbs up Re: Retrofit A4 Front Armrest
    Jul 2007
    Thanks Bwz101
    I take it the console still has to be removed to use the template
    Anybody out there got the template ???
  4. Re: Retrofit A4 Front Armrest
    Jul 2008
    I had the same problem as my kit came from the dealers with NO template?? As it was a saturday, the dealers had closed and i wanted to play!!
    I removed the rear ash tray and done some estimation work, obviously with a steel rule measuring marking it out, slightly smaller than the armrest cove plate, but about 1mm larger than the bottom of the mountin bracket.
    I then drilled a series of holes and cut using a small hacksaw blade. Then used a fine file to take out the excess to the mark. Checking every so often with the base of armrest bracket opened up the hole little further untill it went thru and sat onto fixing stud.
    It took me bout an hour but fitted perfect, I couldnt wait for template.
    Little advise put some old rag in and around the area to catch all the plastic fillings, makes clearing up that much easier .
    AKOYA SILVER B7 A4 2.0 TDI S-LINE BOSE RNS-E/SDS/MFSW VALCONA LEATHER CRUISE ARM REST AMBIENT LIGHT LED INTERIOR LIGHTING DIS S4 MIRROR CAPS BOOT LIP CR SPLITTER 50% TINT
  5. Re: Retrofit A4 Front Armrest
    Jul 2009
    wolverhampton
    Quote Originally Posted by kaab0 View Post
    Hi Kaab0,
    Can i take from your post you didn't need to remove the centre console to fit the arm rest??
    Audi 2.0 TDi 140
  6. Re: Retrofit A4 Front Armrest
    Dec 2007
    no with the template the consol stays fitted save a good few hours work im away this weekend but ill get ur a copy emailed sent ur email addy and ill get it u for monday
  7. Re: Retrofit A4 Front Armrest
    Jun 2008
    Marmitehampton
    I'm pretty sure there is a template in ELSA.... Which I don't have at the moment... Maybe another user does - try asking in hte general thread?
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
  8. Re: Retrofit A4 Front Armrest
    Jul 2008
    Quote Originally Posted by audia4tdv View Post
    Hi Kaab0,
    Sorry for delay no didnt need too, Just pushed forward the seats out of the way. If you dont feel confident wait for the template from one of our fellow members, but its not hard
  9. Re: Retrofit A4 Front Armrest
    May 2007
    knee deep in clunge
    14 Post(s)
    i have a template
  10. Re: Retrofit A4 Front Armrest
    Feb 2016
    midlands
    Quote Originally Posted by a8 tech View Post
    i have a template
    Hi im new to this but been reading through and was wondering if you still have the template for armrest and if you could send me a copy thanks my email is quadrophenic@talktalk.net all the best jamie.
  1. A4 Armrest Again
    By coopl in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-05-2011, 10:36 AM
  2. Tyres & Insurance
    By Sportingmac in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 17-01-2008, 05:59 PM
  3. Replies: 0
    Last Post: 01-08-2007, 08:28 PM
  4. Option Codes
    By Samcat in forum Passat - Archive Topics
    Last Post: 23-11-2006, 11:25 AM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
