Thread: polo sdi creaking and brake pad wear sensor problems
  1. polo sdi creaking and brake pad wear sensor problems
    Sep 2009
    London
    Hi everyone,
    I have an 02 polo sdi which has a creaking noise coming from the nearside front. More prominent over rough road surfaces and strangely when the road is wet. Also when moving off or when car lurches forwards or backwards there is a creak. No sound when the road is smooth. could it be the bushes?
    Also brake pad warning light is constantly on, pads, wire and fluid are fine, could it be the sensor?
    All help would be much appreciated. Thanks
  2. Re: polo sdi creaking and brake pad wear sensor problems
    Jan 2009
    towcester northants
    the creak is either the anti roll bar or its the large wishbone bushes this will also cause car to feel lurchy at front
    on the pad side if your bridge the wires does it cure fault? if so its pads
  3. Re: polo sdi creaking and brake pad wear sensor problems
    Sep 2009
    London
    thanks for your response, the answer is no, it does not cure the fault. I know of someone who replaced the sensor and that seemed to work but i'm not too sure.
  4. Re: polo sdi creaking and brake pad wear sensor problems
    Jan 2009
    towcester northants
    if you bridge the wire and it doesnt cure the fault it will be the wiring to the car from pads
    have tou checked the rear pad warning?
  5. Re: polo sdi creaking and brake pad wear sensor problems
    Sep 2009
    London
    well the car has drums on the back not discs.......
  1. Passat brake noise
    By VWFANN in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-07-2009, 06:41 PM
