Thread: Vac pump
Results 1 to 10 of 12
  1. Vac pump
    Mar 2009
    Can any help.
    I keep loosing vacuum pressure to the servo resulting in hard pedal pressure. After some investigation I traced it back to the were the vac pipe connects to the vac pump, as when I move the vac pipe up & down I can hear a hissing sound coming from the vac pump which I'm sure is not meant to happen.
    Does any one know if the pipe connection on the vac pump is meant to be flexible or fixed (circled in the attached picture) as the one on my vac pump moves when you move the pipe.
    If its not meant to move can it be fixed or do I need to replace the complete unit.
    The engine I have got is a 1.9 TDI (130) engine code AWX.
  2. Re: Vac pump
    135 Post(s)
    2032 Post(s)
    They do move around and hiss a bit, I suspect the leak in the servo hose or in the small 3-mm vac pipe leading off to the EGR/Turbo/manifold flap. Have you had any boost delivery issues?
  3. Re: Vac pump
    Mar 2009
    Hi mate, I have had no boost problems. I've checked all the hoses and they all seem ok. The hissing noise only comes from the hose connection on vac pump.
    I will upload a few more pics tonight to try and help with explaining what I mean.
  4. Re: Vac pump
    Mar 2009
    Here is a pic that should help explain what I mean -
    If I move the vac pipe up & down the connection that sticks out of the vac pump also moves up and down.
    I am not 100% sure of its designed to do this or the connection is broken, as this is were I can hear the hissing.
    I hope it not broken as a new one around £300.
    My mate has got a A4, so I checked his, but his is a newer version and has a different engine code and vac pump.
    Hope someone can help, as it can be a bit scary when you press the brake pedal and its rock solid and the car in front has stopped.
  5. Re: Vac pump
    135 Post(s)
    2032 Post(s)
    Some movement there is quite normal and a small hiss when moved should not cause a loss of vacuum, after all there is a one way check valve in the pipe that maintains any developed vacuum in the servo and engine vac control system. I would check the system by disconnecting the vacuum pipe from thee pump and using a Mitty Vac hand held vacuum pump, I would test the system for vacuum integrity. Using a vacuum gauge I would then test the pumps output and also use the Mitty Vac to test the pumps sealing. If the system was air tight, I would still bee sceptical about replacing the pump, I have had many A4/A6/Passat 3B servos’ fail due to water ingress from blocked plenum chamber drains. If I came to the conclusion that the loose fitting was the problem, I would replace the pump but I would buy one from somewhere like GSF and I think they are made by LUK. To be honest, if you were loosing that much vacuum, I am sure you would be having turbo boost control and EGR problems so a scan of the ECU would bee a good idea.
  6. Re: Vac pump
    Mar 2009
    Hi mate, thanks for your reply. How much are the hand held vac pumps.
    The car had the servo changed a few months ago but still seems to have the problem, I also checked the drains but they were clear.
    I don't seem to be losing any boost as it still feels as powerful as it always has. Could it be a combination of the vac pump & the one way check valve.
    Would i get the same problem if the master cyclinder was faulty?
  1. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  2. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  3. Water pump moral - AAZ engine
    By the_old_diver in forum Early Passat Forum - Pre 97
    Last Post: 19-07-2009, 11:01 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Vac Pipe to Brake Servo
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2008, 11:07 AM
