Thread: Vac pump
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Vac pump
    Mar 2009
    Thanks for the info. Did replacing the pump solve your problem or was there more to it, servo, pipes etc? I will start shopping around!
  2. Re: Vac pump
    Mar 2009
    Hi mate, yes it did solve the problem 100%.
    It took me about 30mins to change it. But due to the vac pump being a tandem type pump (Brake & Fuel) you will have to make sure that when you connect everything back up that you the prime the fuel side of the pump otherwise it will be very difficult to start.
    If you have got a Haynes manual the info on how to change the vac pump is in there.
    Hope this help.
  1. A6 (C5) 1.9 PD TDI Oil Change with Pella
    By Col in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-10-2009, 09:43 PM
  2. 1.9 PD TDI Oil Change with Pella
    By Col in forum General
    Last Post: 21-07-2009, 07:56 PM
  3. Water pump moral - AAZ engine
    By the_old_diver in forum Early Passat Forum - Pre 97
    Last Post: 19-07-2009, 11:01 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Vac Pipe to Brake Servo
    By bg158a in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-02-2008, 11:07 AM
