Thread: Avant heater matrix
Results 1 to 10 of 12
  1. Unhappy Avant heater matrix
    Apr 2007
    Hi, I think my heater matrix might be leaking, when I turn the heater to hot there is a puff of something out of the vent and the screen mists over instantly, theres also a funny smell. Any idea how big a job it is to remove, probably quite major looking at it.
    Thanks Dave
    Mar 2007
    Hi Dave ,Defo sounds as if your matrix has gone....
    Easy or not easy options depending on what you want to do....easy options...1. Good old radweld or similar may work...
    2. Look in engine bay to where coolant pipes go into bulkhead (interior) you can disconnect pipes from matrix here and put a bypass pipe between the two...only problem here is that you won't have any heater....
    Difficult option...
    Replace matrix....I've read somewhere tha Audi start with the heater matrix and then build the car around it...unfortunately true ,the whole dash needs to come off and start from there
    In the mean time check your coolant level regularly...and wear some water-proof shoes cos your footwells are probably gonna get wet!!!
    Regards
    Dom
    Apr 2007
    Thanks, I thought that would be the answer . Might try Radweld etc for now till I find time to strip dash School hols when the car is not needed so much. Stuck my head in the footwell and your right Audi start with the heater!
    Dave
    Oh no, really sorry to hear this mate. It's got to be the worst job to do purely because of how time-consuming it is.
    I thought i'd solved this same problem when i got rid of my last car (Toyota Supra) as that was built around the heater matrix too. Toyota or any other garage for that matter would charge £1k+ to do the job!
    Good luck mate, hope you don't get too wet nor cold.
    If it makes you feel any worse, apparently volvo's heater matrix's are just a case of removing the glove box, undoing and sliding out.
    lol
    Apr 2007
    Yeah its going be a big job.
    Funny thing about the Volvo Id looked at one in the morning before I bought the Audi!
    Dave
  6. Re: Avant heater matrix
    Sep 2007
    Manchester UK
    Hi Scotty just had the same problem with my 2.8 A4 quattro did you manage to get the heater matrix out if so do you have any pointers I have just stripped down the centre console to the metal supports dont really know where to go from here any help would be much appreciated
  7. Re: Avant heater matrix
    Apr 2007
    Hi, Sorry to hear about your A4.Its not a good job, I've attached a pic, PREPARE for a SHOCK!! I had thought about changing the car! except I really like it, so went ahead and did the matrix.
    Took about 6hrs altogether. I have a 2.0 16v 80 Avant so I dont know if the A4 is the same have a good look as to where your heater is. Begin with the lower dash panels and glovebox then steering wheel, column switchs, clocks, center switchs heater controls etc, take your time and if in dout about putting back together label as you go. When put the Dash back in it helps to take the trim of the windscreen posts for clearance, also on mine there are some cable runs under the steering column if the A4 has the same make sure you bolt them back in or the lower panel will fall on your knees.
    Start on a Saturday to get the dash out, then chill out and have a Beer or Two! then put it all back together on Sunday then have more Beer you'll need it.
    Dave
  8. Re: Avant heater matrix
    Sep 2007
    Manchester UK
    Cheers Scotty accomplished it this weekend. I started on Friday morning and finished Saturday dinner time. It took a day to get out and half a day to put back in. I wrote the procedure on the "How To" pages in case anybody else was stuck. Cheers for the help
  9. Re: Avant heater matrix
    It's a big job. did that last year by myself. would reccomend an electric screwdriver. took me in total about 7-8 hours to do it over 2 days.
  10. Re: Avant heater matrix
    Colin300 Guest
    I am currently in the middle of changing the heater matrix on 1991 Audi 80. This thread and others on the forum have been very helpful and helped me have the confidence to get the dash out. Getting it back i is begining to look daunting though!
    But can anyone help me with the next steps? I am looking at the black heater heater box and the ducting to the fan on the passenger side but I can't see the way in to the matrix?
  1. audi a4 avant 1.9 tdi auto heater motor
    By nigel63 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2007, 01:26 PM
  2. Audi 80 tdi..heater matrix
    By domross in forum 80 - 90
    Last Post: 21-03-2007, 11:17 PM
  3. Heater Matrix leaked, Radweld recommended or not??
    By TDI in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-03-2007, 03:15 PM
  4. Heater matrix - no hot air!!!
    By RickT in forum Audi A4 - Archive Topics
    Last Post: 22-02-2007, 08:59 PM
  5. Heater matrix reinstall difficulties
    By narge in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-11-2006, 11:13 PM
