Thread: Clunk from drivers side - lower ball joint or anti roll bar
  1. Clunk from drivers side - lower ball joint or anti roll bar
    London
    For the last 2 weeks only, I am getting a bobble-clunk noise, when I go over a big road pot-hole, from the driver's side of my 1999 Passat 1.8T. It has 90k miles on the clock.
    The drive shafts seem fine and they were only replaced 6 months ago.
    I tightened the upper mountings of the shock absorbers to the specified torque and I generally tried to see if I could spot any obvious wear in the suspension or steering gear brushes, mountings etc.
    Posts here suggest either the "suspension lower ball joint" or the anti-roll bar brushes are prime suspects. How can I narrow down the fault ? Or is there any other fault that I should check first ?
  2. Re: Clunk from drivers side - lower ball joint or anti roll bar
    Jul 2007
    Could be track rod end, just had one done on OHs Passat. Had it fitted by my local independant so he could track it up afterwards.
    £72.00 inc VAT which I thought was OK as the pinch bolt had (as expected) seized.
  3. Re: Clunk from drivers side - lower ball joint or anti roll bar
    Jun 2009
    Telford UK
    Looks like i'm having similar issue but more concerned about the brake judder i have and that could be joint issues also
    Disks and pads changed 12k ago...
    Do you have any brake issues also
  1. Replacing Anti roll bar
    By Huxly in forum Golf MK4 - 1999 - 2004
    Last Post: 18-04-2011, 10:46 AM
  2. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  3. Split rear anti roll bar
    By nutter1980 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2008, 02:31 PM
  4. Sqeaking on my Audi TT
    By Ants TT in forum Chat - Completely Off Topic
    Last Post: 10-08-2006, 12:07 AM
