Thread: Turbo Pipe Vibrations
  1. Turbo Pipe Vibrations
    Jul 2009
    Bristol, UK
    Apparently if the 'seal' in the Turbo Pipe or Air Pipes around the Turbo/Intercooler goes through high pressure, you get the bad vibration between 800-1500rpm.
    I get this problem and its a weird one. If you blip the throttle before pulling away, hence spinning up the turbo, you don't get the vibration. Definately sounds like it maybe the cause of my issue.
    Anyone got any experience of this? Supposedly its a 'pennies' seal and can be changed in 5 minutes,
  2. Re: Turbo Pipe Vibrations
    Chester-le-Street, United Kingdom
    Quote Originally Posted by hutch_2002 View Post
    not quite sure what you are trying to say here, but "blipping the throttle before pulling away" won't get the turbo to spool up.
    you need load on the car to get the turbo working.
    i have had an "aftermarket" front flexi / cat fitted about ten mths now,and that has vibrated since the day it went on. i didn't take it back because you only get what you pay for.
    regards,
    stewy.
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: Turbo Pipe Vibrations
    131 Post(s)
    1978 Post(s)
    Petrol or diesel?
  4. Re: Turbo Pipe Vibrations
    Jul 2009
    Bristol, UK
    It's a 1.9 GT TDi 150.
  5. Re: Turbo Pipe Vibrations
    131 Post(s)
    1978 Post(s)
    The across engine front boost pipe from the intercooler to the inlet manifold can break away from its mounts and fail at the bottom where it meets the rubber elbow.
  1. Please Help Turbo failure again-help please!!!!!!!
    By Tyanu888 in forum Golf MK5 - 2004 - 2009
    Last Post: 17-03-2011, 09:18 PM
  2. Please Help tdi 130 mark 4 o2 plate turbo air intake pipe oil leak
    By homerj9 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-05-2008, 06:14 PM
  3. 2002 TDI 130 Sport, Split Lower Turbo Pipe
    By btracing in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-04-2008, 07:24 PM
  4. Pipe advice 1.8 Turbo
    By sp33dy in forum Chat - Anything with wheels
    Last Post: 13-10-2007, 03:32 PM
  5. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
