Thread: Key Fob doesn't unlock boot and doors together
  1. Key Fob doesn't unlock boot and doors together
    Aug 2007
    Weybridge
    Hi All,
    My key fob's (both of them) have just stopped unlocking the boot when you press the unlock button (bottom button on the key fob).
    Previously when I've pressed the bottom button the whole car has unlocked, now I can only unlock the boot on the middle, boot button which means I have to stop and turn the car off to get anything out, any suggestions / help much appreciated.
  2. Re: Key Fob doesn't unlock boot and doors together
    Mansfield, UK
    It would be worth disconnecting the battery for 10 minutes or so to reset the convenience module, it may be a little confused.
  3. Re: Key Fob doesn't unlock boot and doors together
    I had this, sombody was after changing the position of what looks like a key slot in the boot. If you moved this it will stop the boot opening with the doors. Solved my issue anyway!
  4. Re: Key Fob doesn't unlock boot and doors together
    Aug 2007
    Weybridge
    Quote Originally Posted by JohnyIre View Post
    Perfect............. just solved mine to! Thanks for your help
  5. Re: Key Fob doesn't unlock boot and doors together
    Quote Originally Posted by The Glove View Post
    No problems, very annoying when you didn't change it yourself. Last time I give the keys to somebody again!
  1. Key Fob
    By russellm72 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-11-2008, 09:53 AM
  2. Boot will not lock (manually or from the fob)
    By cirrus61 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2008, 02:43 PM
  3. Passat Boot Only Opens Manually.
    By Studio54 in forum Passat - Archive Topics
    Last Post: 27-01-2008, 07:51 PM
  4. Key Fobs and Central Locking
    By jamez100 in forum Golf MK4 - 1999 - 2004
    Last Post: 31-12-2007, 04:31 PM
  5. Boot / Tailgate Central Locking Does Not Work.
    By Studio54 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-07-2007, 12:16 AM
