Thread: Oil leak from the EGR
  1. Oil leak from the EGR
    Feb 2007
    I have just noticed an oil leak on my A6, its the 1.9tdi 115PD. its coming from the middle to top of the egr and is dripping onto the meshed part of the exhaust. Does oil circulate through the EGR and has anyone ever experienced this.
    Someone has told me things like this happen when the car is 'babied' i.e. never really driven very hard. this then causes the intake and turbo to become clogged, could this happen?
    thanks
    will
    Apr 2007
    I'd be interested to hear anything on this.
    I have the same problem (but no resources so am checking the forums out).
    I also intermittently lose my power and think it is connected with the EGR leak.
    I have a Skoda Superb 1.9TDI 130
    Apr 2007
    East midlands
    You are about the 4th time I've come across this problem in about 3 weeks, I found oil coming from the small hole in front of the EGR, I posted it on this forum ("tdi turbo oil escaping everywhere") and got plenty of feedback. I'm interested in the fact that 'babying' can cause this, I drive pretty conservatively but I give it a good rev every now and then. The only other probable I have is the fact that I took car to a crap garage and they overfilled the engine oil, there's oil in all the air pipes from turbo to intercooler, this suggests a leak in the turbo, no performance issues though (fingers crossed!) Have a look round the tech forum, there's loads in it.
    I have a gttdi 130 by the way, hope this helps you or anyone,
    Swanny
    Feb 2006
    every single tdi model within vag ranges have oil in boost pipes and egr...near enough everywhere. normall. so common to even leak from intercooler pipes. nothing to worry about if small amount. be more worried if found water. diesels are known to be oil burners/users
    Feb 2007
    The garage ive been going to has been overfilling the oil as well. I know there is supposed to be som eoil in the pipes but the amount of oil coming out of the EGR is causing it to drip onto the exhaust pipe, which cant be right, also ive had to top it up a bit more recently with oil.
    Feb 2006
    yeah you are rite....as it tells you on the oil cap..if engine oil overfilled it will spill into catalyst and cause damage....etc...too much or too little of everything cause problems and level need to be obtained.
    i once worked on a car that wouldnt start because the customer had fill the engine oil up....but he litterally filled it to the cap but several litres in and dint realise what a dipstick was for.,...lol
    Apr 2007
    East midlands
    That's nothing, I've seen oil topped up through the dipstick hole, classic!
    Does oil coming from EGR mean there is a seal gone somewhere or will it stop if I drain some oil out, it's hard to tell what's normal with these engines and what's a problem, oil everywhere!
  1. Vacuum leak
    By andrewaudi in forum 80 - 90
    Last Post: 11-04-2007, 06:53 PM
  2. TDI 130 turbo oil leak
    By Swanny130 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-04-2007, 10:59 AM
  3. Engine oil leak
    By tel7448 in forum Passat - Archive Topics
    Last Post: 01-04-2007, 10:30 AM
  4. Oil leak / Mist
    By tea drinker in forum Passat - Archive Topics
    Last Post: 17-03-2007, 06:53 PM
  5. leak in boot
    By blebird in forum Passat - Archive Topics
    Last Post: 12-03-2007, 03:51 PM
