Thread: 1.9 TDI service question....please :)
  1. 1.9 TDI service question....please :)
    Jun 2009
    Tranby, Norway
    I've had the 2001 1.9 TDI Passat wagon for a couple of months now. I really like it!
    The 'service in 3000km' warning is showing up on starting now.
    The car has done 130,000 km, what is actually done on this service, I have always done my own oil changes ect.
    Is there anything special for this service?
    cheers,
    -John
  2. Re: 1.9 TDI service question....please :)
    Norfolk
    It depends what was done on the last service. I would change the oil and filter, air filter, pollen filter and fuel filter. Then you know you are good for at least a year or 15,000km. Check brakes all round and consider changing brake fluid if you don't know when it was last done. Coolant should be ok but if unsure ask a garage to check with a refractometer, not a hand tester. As DIY goes, it's all easy work.
  3. Re: 1.9 TDI service question....please :)
    Jun 2009
    Tranby, Norway
    Thanks Martin,
    sorry for the VERY late reply!!!
    I have been away for months and have finally returned and done my service: oli, oil filter, air cleaner/(pollen filter?). I have a fuel filter but didn't have the correct size hex key to undo the fuel filter, I'll get one from work next week.
    After putting everything back together I went for a test drive and found an unexplained problem to do with the turbo system, I'll start another thread no and see if I can get some help,
    thanks again,
    cheers,
    -John (aussie in Norway)
  1. Trim Confusion
    By ocelot0411 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-08-2009, 11:16 AM
  2. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  3. Audi covers new ground with 2010 q7 suv
  4. Intense TDI power - The Audi A3 TDI clubsport quattro
    Last Post: 18-05-2008, 10:12 AM
  5. NEW TOURAN AVAILABLE TO ORDER NOW AHEAD OF JANUARY LAUNCH
    Last Post: 04-12-2006, 08:10 PM
