Thread: Rear speaker and sub problems
  1. Rear speaker and sub problems
    Dec 2006
    I have a 2000, X reg 1.8 A3 which does not have the Bose sound system installed. The original Concert stereo had the dredded volume problem so when i got the car I replaced it with a unit that was working.
    The guy that had the car before disconnected the rear speakers and sub inorder to use the fadder as volume control.
    I now need to reconnect these but cant access the rear speakers or the connector for the sub. Does anyone know how I can do this.
    They are connected at the rear of the stereo so they disconnections must have been at the speakers themselves.
    Thanks in advance.
    Dec 2006
    Wiltshire
    The rear speakers and sub are all connected to the top pre-out connector on the Concert, if that's connected correctly, the only other place they could easily be disconnected would be at the rear speaker/sub connection - r/h side of the boot behind a panel.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
    Dec 2006
    Thanks for that but would the connector not be at the left hand side next to the sub itself.
    Dec 2006
    Righty, I have had a look at the connector next to the sub but it looks like all the wiring is ok. Im pretty sure it is ok at the rear of the head unit too. Do you know what wires go where at the rear of the head unit as this is the only other place that i can this is easy to access.
    Thanks in advance
    Dec 2006
    Wiltshire
    On the radio rear connector there are 4 distinct sections. As you look at the back of the unit it's the top section with the multi-pin connector you're interested in, See the attachment.
    C chamber has the rear pre-outs. Pins 1,2,3,4 & 5
    Dec 2006
    Thanks for that froggy, I just had a look now. But all seems ok there - great diargam by the way its a good one to have.
    And all is ok at the connector block beside the sub - I cant imagine that he would have went to the bother of getting into the rear speakers but who knows.
    Im stumped!
    Any Sugesstions?
    Dec 2006
    Wiltshire
    I wonder if he disabled the amps rather than disconnecting anything, it would actually be the easiest way of disabling all the rear speakers.
    Check he hasn't pulled a fuse from somewhere or disconnected the amp switch on wire somewhere. Other than that - I'm as stumped as you are.
    Dec 2006
    Manchester
    Quote Originally Posted by Froggy View Post
    1 way to check this would be to see if the amp gets warm......
    Good luck
    Nick
  9. Still no joy
    Dec 2006
    Hi guys - Thanks for your help.
    It does not look like there are any fuses been removed or any loose wires from anywhere.
    Where is the amp located. I though that it just had a pre amp in the head unit itself since I dont have the Bose system.
  1. Avant Rear speaker & amp
    By oldgranite in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-11-2009, 07:11 PM
  2. Help! silly question on rear speaker removal apologies!
    By bibble in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-08-2007, 06:34 PM
  3. Speaker sizes?
    By tweeky in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-03-2007, 06:20 PM
  4. Problems Changing Rear Brake Pads
    By DiverDave in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-02-2007, 06:20 PM
  5. Advice please - Sharan rear speaker install??
    By runningpuffingbilly in forum Touran - Sharan - Caravelle
    Last Post: 23-01-2007, 01:27 PM
