Thread: Fabia Temp Sender......
Results 1 to 10 of 12
  1. Fabia Temp Sender......
    Feb 2007
    Where on a 2004 Fabia 1.9 TDI engine code atd can i find the temp sender (g62)?
    Thanks in advance
    '12 Audi A4 Allroad 2.0 TDI 'CGLC'
    '11 VW GOLF BLUEMOTION 1.6 TDI. 'CAYC'
    '07 VW T5 TRANSPORTER T32 ,,,,,, 'BNZ'
    '91 VW GOLF SPORTLINE CABRIOLET 1.8 GTI. 'DX'
  2. Re: Fabia Temp Sender......
    2005 Post(s)
    On the end of the head over the gearbox pointing towards the bulkhead.
  3. Re: Fabia Temp Sender......
    Feb 2007
    I thought as much but thanks for clearing that up.I was getting the following code....17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
    P1256 - 35-10 - - - Intermittent
    Readiness: 0 1 0 0 0
    so got the owner to buy a new temp sender but the fault has reappeared.According to ross tech wiki it could be the wiring.
    Is the wiring prone in any particular area???
  4. Re: Fabia Temp Sender......
    Feb 2007
    Forgot to mention that the car is not suffering from any of the listed symptoms on ross tech wiki only the stored fault code and the coolant symbol on the dash.
  5. Re: Fabia Temp Sender......
    2005 Post(s)
    No they are not prone to wiring issues. Coolant symbol? You mean the low water level? That is in the bottle and nothing to do with the temp sender.
  6. Re: Fabia Temp Sender......
    Feb 2007
    Thanks Crasher.In that case i may be looking at an extra fault.I think the coolant symbol stays steady when it comes on.Does that mean low coolant level which it isn't or overheating???
  7. Re: Fabia Temp Sender......
    2005 Post(s)
    You have a coolant temp sender fault code so that needs replacing.
  8. Re: Fabia Temp Sender......
    Feb 2007
    I'm confused now......I've already changed the coolant temp sender once!!!Just to clarify i changed the right one,it's next to the cylinder head is a push fit and is grey in colour.
  9. Re: Fabia Temp Sender......
    2005 Post(s)
    So am I, you must have a wiring issue.
  10. Re: Fabia Temp Sender......
    Aug 2021
    W mids
    I have a cooling problem of no fans are kicking in ?
  1. A quick tip re temp sender
    By darkhorse1001 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-05-2008, 11:55 AM
  2. Temp guage and sender issue
    By pedro B in forum 80 - 90
    Last Post: 04-03-2008, 06:14 PM
  3. Where is my Temp Sender located?
    By pg20 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-02-2008, 09:03 PM
  4. New Škoda Fabia Estate Uk Pricing And Spec Is Announced
    Last Post: 03-12-2007, 08:08 PM
  5. Passat PD 130BHP Temp sender location?
    By alba_tdi in forum Passat - Archive Topics
    Last Post: 07-07-2006, 08:15 PM
