Thread: passat s tdi 130 auto - engine power loss, exhaust smoke
Results 1 to 8 of 8
  1. passat s tdi 130 auto - engine power loss, exhaust smoke
    Aug 2009
    fife
    Hello,
    First post. I recently bought a second hand passat s tdi 130 auto (52 plate) and have a couple of issues that I would be grateful for advice on.
    Occasionally when I put my foot down hard on the accelerator, the car doesn't pull very well, as if the turbo isn't kicking in. The engine then stays in this state until the ignition is switched on and off and then all seems to be fine again. At no time are there any warning lights on the dash.
    Secondly, when pulling away from stationary, and regardless of how gentle or hard I accelerate away, a cloud blueish smoke is emitted from the exhaust(presumably smoke?).
    Are either of these issues something to worry about?
    Thanks in advance.
  2. Re: passat s tdi 130 auto - engine power loss, exhaust smoke
    Norfolk
    The lack of power is the engine going into limp mode probably because of a turbo fault. You need to get a code read done to find out if you have over boost or under boost. Once you know, people will be able to give you more useful advice.
  3. Re: passat s tdi 130 auto - engine power loss, exhaust smoke
    Mar 2007
    Quote Originally Posted by hoffmeister View Post
    Hello,
    Thanks in advance.
    Thats your turbo on its way out. I suggest you check your engine oil level quickly. DO NOT DRIVE YOUR CAR STOP NOW AND YOU CAN recon your turbo. CONTINUE DRIVING and you will need a new one. i know a very good recon place lmk
  4. Re: passat s tdi 130 auto - engine power loss, exhaust smoke
    Jul 2008
    Beverley, East Yorkshire
    Hello,
    Thanks in advance.
    If it turns out to be an overboosting turbo when you get a code reading, a search on the forum will lead to plenty of solutions - I had similar symptoms which turned out to be a turbo overboost problem - great advice from forum members saved me £1000!
  5. Re: passat s tdi 130 auto - engine power loss, exhaust smoke
    Mar 2007
    odds on its a dirty/sticking turbo , get some innotec cleaner £38 delivered and follow the instructions ,
    its a bit of a fiddle but not too hard to do.
    the turbo may respond to the cleaning or it may have go for a rebuild , but it worked for me.
  6. Re: passat s tdi 130 auto - engine power loss, exhaust smoke
    Aug 2009
    fife
    Thanks for the useful advice.
    I'm getting it looked at during the week to see which, if any codes are being registered and also having the turbo looked at.
  7. Re: passat s tdi 130 auto - engine power loss, exhaust smoke
    Aug 2009
    fife
    Well, had it looked at.
    It was logging a fault 17965 which apparently corresponds to P1557, something to do with pressure control deviation. Apparently an overboosting issue.
    They had a quick check of the pipes and they may have spotted a loose one, so that will be getting replaced later in the week. They also put in some diesel fuel additive to see if that would help the smoking issue.
    Bit of googling led me to this:
    http://wiki.ross-tech.com/index.php/17965/P1557/005463
    Which has:
    17965/P1557/005463 - Charge Pressure Control: Positive Deviation
    Possible Symptoms
    Reduced power output
    Limp mode
    Possible Causes
    Boost Pressure too High
    Hoses/Pipes incorrect connected, disconnected, blocked or leaking
    Charger Pressure Control defective
    VNT (variable nozzle turbo): nozzles stuck
    Solenoid Valve for Boost Pressure Control (N75) defective
    Possible Solutions
    Check Hoses/Pipes to/between Components
    Check Solenoid Valve for Boost Pressure Control (N75)
    Check / Clean / Replace Charge Pressure Control
    Check / Clean mechanism for variable nozzles
    I'm not particularly knowledgeable, but it looks like something to go on.
  8. Re: passat s tdi 130 auto - engine power loss, exhaust smoke
    Norfolk
    Overboost is not likely to be due to a loose pipe. The most likelt faults are faulty MAP sensor, faulty MAP solenoid (N75), faulty VNT actuator or stuck vanes in the turbo. On rare occasions a blocked pipe running from the N75 solenoid to the air filter can cause this. The most likely cause as already suggested is stuck turbo vanes.
  1. Replies: 0
    Last Post: 03-07-2009, 07:48 PM
  2. Audi covers new ground with 2010 q7 suv
    Last Post: 15-04-2009, 08:08 PM
  3. Please Help Loss of Power Passat TDI - IN the Morning
    By RichardCaul in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2009, 05:18 PM
  4. Answers From The Oil Expert Part 2
    By oilman in forum Archive posts
    Last Post: 22-10-2007, 08:30 AM
  5. How does the Quattro system work?
